The only way it will make a difference in tire wear is if you are constantly spinning the tires and wearing them prematurely. If you are just turning traction control off but not spinning the tires any more than before you will not have any more wear.
No, that would be true if you had all wheel drive. Traction control puts traction where it is needed. It won't wear tires out.
SOURCE: spark plugs on 2002 Saturn vue
just completed a plug removal and install on my '02 awd v6. if you have the time and patience it's straight forward; common sense was most helpful. to gain access to the plugs, both fore and aft, you must remove, in short, everything near to, associated with, the air intake system. common tools plus a 1/4 socket, with 8 inch extension to hold a #10 star bit. these star bolts are under the rectangular plastic plate atop the intake. once you have those out, disconnect all the wiring, carefully. lift the intake out, look for plug covers, fore and aft, ignition assembly lays atop each row of three plugs. with the hands of a surgeon, remove the ignition assembly, and by golly ye shall see your reward. easy from then on.
replaced my plugs with the iridium 'honeys'; marked improvement in starting, acceleration, smoothnes, noise, and gas mileage to the value of + 3.0%. changed out the oil with mobile1 extended performance, changed transmission fluid. took a shower. time involved, 7.0 hrs. dealer be damned,,priceless!
SOURCE: 2002 Saturn Vue V6 Loss of Power
Yup. The throttle body connectors have a history of failing on these cars. Replace the throttle body and the wire connectors that go to it, and you're back in business. Not terribly difficult and you can get the parts from any dealer. Saturn actually has a bulletin out on this problem but they won't cover it unless you're under warranty - no recall for this.
SOURCE: 2002 Saturn Vue Transmission problems.
that trans. is verry expensive. talk to saturn dealer, there is a special extended warranty on that trans.
SOURCE: 2002 Saturn Vue Ignition Cylinder lock problem
The keys on this vehicle have a problem with wearing down to the point where it's a pain to get them to work in the ignition cylinder. Examine your keys for wear and that may have been your problem since day one.
I have a 2004 Vue and I have the only key I got with it (used car) worn down to the point where it will no longer work in the back door and is a pain to use in the ignition cylinder. It also falls right out of the ignition cylinder when the car is running. I have a copy of the key that was made when I got the car which works just fine and doesn't fall out, and looking at the two side by side, you can see that Saturn's key has worn down substantially since I got it two years ago.
