Copy from VHS to DVD after a minute stops the copy and gives error message that the DVD may br defective.
I called Papasonic and they are sending a software update
Posted on Dec 01, 2008
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
You say "home made" - not sure what you mean by that. If it was a copy of something that was originally retail, it's possible the Macrovision encoding copied over with it - in which case your DVD recorder is working as it's supposed to to prevent illegal copying of disks. I'm a bit wary of getting into this in any depth, as it treads the lines of legality. If I found a way for you to bypass this copy protection, it would allow you to pirate movies freely. I'm not going to discuss my own feelings on that, but I will say that I'm not going to support such actions on a public forum. That being said, if for some reason your totally legitimate home made tape managed to get something that's being interpreted as Macrovision coding on it, you may want to do a google search for digital video stabilizer. That will point you in the right direction.
Aug 12, 2007 | Toshiba DR4 DVD Recorder
I've had this unit ewr20v4 for about 5 years, never tried to copy from vhs to dvd until now. I get error message, unable to copy to this disk. called CS they offered an upgrade disc but will charge me...
You have a VHS that uses copy protection. Your unit is designed for copying self-authored DVDs, like you make from iMovie or another app, to VHS. It won't work with commercial VHS tapes with copy protection. The upgrade is probably a decoder circuit, and may be worth it if you plan to use your unit this way often.
Mar 21, 2011 | Emerson EWR20V4 DVD Recorder/VCR
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Recorded in VX530 DVD only plays in the VX530
it needs to br a dvd-r and formated in video mode. when done recording it needs to be finalized . see manual for procedure
Apr 11, 2009 | Sony RDR-VX530 DVD Recorder/VCR
VR5940 DVD Recorder/VCR-Thinks a regular VHS tape is copyright protected
Don't know your machine, but is it possible that it's seeing your source tape as write protected (missing tab) and so assuming it should not be copied to the DVD?
Jun 14, 2017 | GoVideo VR5940 DVD Recorder/VCR
Panasonic dmr-eh75v dvd won't work
dirty lens, broken ribbon connections or adjust the bias of the lens place at the back of the lens.....
May 08, 2008 | Televison & Video
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
Mar 06, 2007 | Sylvania SRDV495
Televison & Video Logo
Top Televison & Video Experts
