Question about Kenmore Elite 45986 Front Load Washer
Shock absorber on my HE 3t has come off it's mount.
The shock absorber is in the rear of the machine. Is there an easy way to put it back on?
  • vale8888 Dec 04, 2008
    Mike73, Thanks it only took me 10 minutes to do and that included pulling the machine out removing the cover put back together and pushing the machine back. BIG HELP!!! Thanks again.
  • 240 Answers
Use screwdriver to unlock tab at tub and twist off reassemble and twist to lock. sometime these dont work well after coming apart and should be replaced.
Posted on Dec 03, 2008
My van shimies left and right badly....and it pulls to the left....it does it more when going straight and not so much when going around curves
check the vans rear shock absorbers if they are faulty the car can exhibit this type of behaviour and braking will be less efficient. Also tyre wear will be affected to.
I am not a shock absorber expert but had recently my four shock absorbers replaced as the fluid had ruptured in the front shockers and the rear mounts for the rear shockers were corroded and unsafe. (shock absorber expert at repair place mentioned the symptoms you are describing as a rear shock problem or the rear leaf springs are faulty)
Mar 18, 2015 | Cars & Trucks
How to replace rear shocks
Removal & Installation
  1. Raise and safely support the vehicle.
  2. Support the rear axle and slightly lower the vehicle enough to lessen tension on the shock absorber.
  3. Remove the lower shock absorber retaining nut and washer.
  4. Disconnect the lower end of the shock absorber from the mounting stud.
  5. Remove the shock absorber upper end retaining nut and washer.
  6. Remove the shock absorber from the vehicle.
To install:
  1. Install the shock absorber onto the upper and lower mounting studs of the vehicle.
  2. Install the washers and retaining nuts. Tighten the upper and lower retaining nuts to 22-30 ft. lbs. (30-41 Nm) on 2001-02 models or 22 ft. lbs. (30 Nm) for the upper bolts and 47 ft. lbs. (64 Nm) on the lower bolts.
  3. Lower the vehicle.
Jul 07, 2014 | 2004 Nissan Quest
I need to remove the entire passenger side rear suspension. Does it go through the trunk or the back seat? If so how do you remove the back seat?
REMOVAL & INSTALLATION 1983-86 Models
  1. On 4-door sedan, remove the package tray and vent duct.
  2. On hatchback, remove the speaker grilles.
  3. Disconnect the brake line from the wheel cylinder. CAUTION
    Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
  4. Remove the brake line from the brake hose.
  5. Disconnect the brake hose from its bracket on the shock absorber.
  6. Loosen, but do not remove, the nut holding the suspension support to the shock absorber.
  7. Unbolt the shock absorber from the rear arm.
  8. Unbolt and extract the shock absorber from the body. To install:
  9. Attach the shock absorber to the body and tighten the 3 nuts to 17 ft. lbs. (25 Nm).
  10. Engage the shock absorber bracket with the carrier and install the hardware. Tighten the nuts to 119 ft. lbs. (162 Nm).
  11. Tighten the center suspension support nut to 36 ft. lbs. (49 Nm). There is a bearing located under the suspension support dust cover. Remove the dust cover and pack the bearing with multi-purpose grease. Once packed, reinstall the dust cover.
  12. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  13. Have the rear wheel alignment checked.
1987-88 Models
  1. On wagon models, remove the toneau cover holder.
  2. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  3. Remove the rear wheels.
  4. Using the proper size flare nut wrench, disconnect the backing plate hardware.
  5. With a flare nut and a back-up wrench, disconnect the brake tube from the brake hose and use a small plastic container to collect the brake fluid.
  6. Undo the clip and disconnect the brake hose from the shock absorber. NOTE: Before the axle bolts are removed, the axle carrier must be supported with a jack.
  7. Support the axle carrier with a floor jack and remove the mounting bolts and nut. Disconnect the axle carrier from the shock absorber.
  8. Support the shock absorber firmly by hand and remove the three mounting nuts. Remove the shock absorber from the body. To install:
  9. Position the shock absorber onto the body and support it firmly by hand. Install the three nuts and tighten them to 23 ft. lbs. (31 Nm).
  10. Attach the axle carrier to the shock absorber with the nuts and bolts. Tighten the nuts to 166 ft. lbs. (226 Nm).
  11. The remainder of installation is the reverse of removal. Tighten each component to specifications.
  12. Bleed the brake lines as described in Section 9.
1989-96 Models
  1. On the 4-door sedan, remove the package tray and vent duct. On 1992-96 models, it will be necessary to remove the rear seat back.
  2. On the hatchback, remove the speaker grilles.
  3. On the wagon models remove the tonnue cover and rear seat back.
  4. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
  5. Remove the rear wheels.
  6. Disconnect the brake hose and the ABS speed sensor from the shock absorber.
  7. If equipped with ABS, disconnect the Load Sensing Proportioning Valve (LSPV) spring from the lower arm.
  8. Disconnect the stabilizer bar link from the shock absorber.
  9. Support the rear axle and loosen the 2 bolts from the lower end of the shock absorber.
  10. From inside the vehicle, unbolt the upper support. Fig. 1: A rubber cap covers the rear shock absorber tower nut 89558p01.jpg
    Fig. 2: The upper shock absorber tower is retained by the center nut (circled) and three surrounding nuts 89558p02.jpg
  11. Lower the rear axle carrier and remove the two bolts.
  12. Remove the shock absorber from the vehicle. To install:
  13. Install the shock absorber assembly onto the vehicle.
  14. Connect the brake hose and the ABS speed sensor to the shock absorber.
  15. Connect the stabilizer bar link to the shock absorber.
  16. Install the wheel and tire assembly.
  17. During installation, please observe the following tighten specifications:
    1. Tighten the shock absorber-to-body bolts to 29 ft. lbs. (39 Nm).
    2. Tighten the shock absorber-to-axle carrier nuts to 166 ft. lbs. (226 Nm) on 1988-91 vehicles and 188 ft. lbs. (255 Nm) on 1992-96 vehicles.
    3. Tighten the suspension support-to-shock absorber nut to 36 ft. lbs. (49 Nm) on 1988-91 vehicles. On 1992-96 models, tighten the stabilizer bar link to shock absorber retainers to 47 ft. lbs. (64 Nm).
  18. Install the rear seat back, vent duct and the package tray as required.
Dec 18, 2010 | 1986 Toyota Camry
Need new struts on rear, Would like to replace with air shocks. Any suggestions on how I would do this?
Shock Absorber -The rear already has air shocks on the 1999 Cadillac Deville: REMOVAL & INSTALLATION Rear
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Rear wheel Fig. 1: Exploded view of the rear shock absorber mounting 9300vg06.gif
    • Negative battery cable
    • Shock absorber electrical connector from the rear suspension support, If equipped
  3. Support the lower control arm with a jack to relieve the tension on the shock absorber.
  4. Remove or disconnect the following:
    • Lower shock absorber mounting bolt and nut
    • Upper mounting nut, retainer, and insulator
    • Shock absorber compress by hand and remove through the upper control arm
    To install:
  5. Position the top of the shock absorber with the insulator attached into the suspension support.
  6. Install or connect the following:
    • Upper shock insulator, retainer and nut. Torque the nut to 55 ft. lbs. (74 Nm).
    • Shock absorber lower mounting nut/bolt. Torque the nut to 75 ft. lbs. (102 Nm).
    • Shock absorber electrical connector to the rear suspension support, if equipped
    • Rear wheel
Jul 29, 2010 | 1999 Cadillac DeVille
Do i have to remove the back seat to take rear struts off
Answer
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle (Shock Absorber Attachment To Knuckle).
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening
Nov 23, 2009 | 2002 Dodge Stratus
Are their any speical problems or tricks in replacing air adjustable rear schocks on a 2001 buick custom
  1. Remove the tire and wheel assembly.
  2. Support the control arm with a jack stand.
    0900c152802427b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Use support bracket tool J-23028-01 mounted on a jack to support the rear lower control arm
  3. Remove or disconnect the following:
    Electronic Ride Control (ELC) air tube from the shock Two bolts securing the shock to the control arm Trunk trim to gain access to the shock upper mounting nuts. Cover, the two nuts, and the reinforcement from the top of the shock Shock from the vehicle
    0900c152802427e1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the cover to gain access to the upper shock absorber mounting components-rear suspension
    0900c152802427e2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the lower shock absorber mounting to the knuckle assembly-rear suspension
To install:
Shock, reinforcement, and the two nuts. Tighten the mounting nuts to 15 ft. lbs. (20 Nm). Shock cover Trunk trim Shock-to-control arm bolts and tighten the bolts to 18 ft. lbs. (24 Nm) ELC air tube to the shock. Tire and wheel assembly
Apr 09, 2009 | 2001 Buick LeSabre
Shocks
rear
5955ba5.gif ------------------------------------------------------------------------------------------
front
Removal
  1. Remove front shock absorber-to-upper shock bracket nut and bolt.
  1. Disconnect the lower end of the front shock absorber bolt and nut from the U-bolt plate.
  1. Compress the front shock absorber and remove.
Installation
  1. Insert front shock absorber into the front shock absorber mounting bracket (18183). Insert bolt and tighten nut to 60-81 Nm (45-60 lb-ft).
  1. Attach the lower end of the front shock absorber to the U-bolt plate by installing the nut and bolt. Tighten to 60-81 Nm (45-60 lb-ft).
front
Feb 04, 2009 | 1996 Ford F350 Crew Cab
Information on how to change rear shock absorbers
with great difficulty,three bolts hold the plate that takes the top bush/mounting .jack vehicle up and support with axle stand .Another jack under rear axle ,jack this one up till cars starts to lift then fit the spring clamps and compress the spring.Next undo the 3/4 13mm headed bolts that hold the plate to the chassis ,if you can release them???---??? ,then next using a small bottle jack take the strain on the bottom of the shock absorber and then remove the bolt ,lower the jack and the top one will lower as well ,undo the two nuts on the top mounting and pull the old shock absorber out .Or what i do if back is dancing and thats to do as above to support vehicle ,support lower of shock absorber ,remove the bolt and then jack it up ,then drill a small hole about an inch from the top of the tube and then thread it ,refill the shock absorber with a heavier oil like dextron .fit a bolt into the hole with a rubber washer and its as good as new
Aug 12, 2008 | Jaguar XJ6 Cars & Trucks
2004 dodge stratus SE
This is a dangerous job if you do not have the proper equipment for compressing the spring that is around the rear shock. I do not recomend performing this job without the proper equipment. Unloading the spring without it compressed can cuase injury.
If you have the proper equipment this is how you do it.
REMOVAL - SHOCK ASSEMBLY NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
  1. Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
  2. Remove plastic cover from the top of the shock assembly.
  3. Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
  4. Raise vehicle on jackstands or centered on a frame contact type hoist.
  5. Remove the rear wheel and tire assembly from the vehicle.
  6. Remove two fasteners holding the splash shield to the shock assembly upper mount.
  7. Remove bolt attaching shock absorber to rear knuckle
  8. Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
  9. Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening.
Aug 04, 2008 | 2004 Dodge Neon
Kenmore Elite 45986 Front Load Washer Logo
239 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
