Question about Dell Latitude D600 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
Able to boot from Windows XP CD but does not see the new HD when it comes time to write to the HD. HD model is Hitachi HTS424030M9AT00 ATA/IDE. Downloaded the drivers for the HD and attempt to press F6 during the boot process but the system tell me it is looking for a floppy drive to read from. I changed the boot process, disabling the search for a floppy. Do these HDs need any jumpers applied? Currently it is set up for Device 0 which should be right.
  • Ken Clemmer Nov 30, 2008
    Mr. Geekman,
    I thank you for the info. No luck as yet. The BIOS, Version A16, only reflects None in the Primary Hard Drive. Does not allow me to modify anything. Have not tried fdisk or the adapter option.
    Ken
  • Dell Master
  • 32,281 Answers
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Posted on Nov 30, 2008
  • Chris Hingee
    Chris Hingee Dec 01, 2008
    If you see none in the primary drive that means the hard drive is dead, or the hard drive controller has died, Most likely dead drive.
My latitude d600 wont start up!
hi, your windows explorer is corrupted. to solve this, simply insert the xp installation cd and boot from it. then run repair to fix the os. note your files will not be lost
Jan 24, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Purchased latitude d600 from sale how can I install my windows xp
Press F12 as you boot up the Dell and select the CD as the alternate boot device, insert the Windows installation CD in the CD drive and continue.
If you can't select the CD as the alternate boot device then go into the BIOS configuration then the Boot order and select the CD as the first boot device, save and exit. You can change it back after Windows is installed if you wish.
Jul 18, 2009 | Dell Latitude D600 Notebook
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Dell Latitude 60 Laptop Won't Load windows
You can either press F8 repeatedly at boot or the Delete key for setup to change the boot drive to cd with the Windows cd. F12 will get you a one time boot option as well. Steve
Jan 26, 2009 | Dell Latitude D600 Notebook
Dell D600 CD/DVD boot problem
Looks like you already have Win XP install on ur machine....why you need to boot by using cd? do u want to reformat your pc or upgrade it?
Sep 21, 2008 | Dell Latitude D600 Notebook
Dell "Drivers and Utilities" CD
Hi, the "No Diagnostic Utility Partition Found" is returned because your laptop does not find the recovery partition on C drive.
Easiest way to create partition is with dell recovery cd. You can buy CDs from dell, buy finding contact on web site or buy from one of the following.
Dell Restore Disk: XP Pro SP2 for ... $35.00 - DIMOSOL - Digital ...
Dell Latitude D600 XP System Recovery CD ... $18.95 - recovery-cds.com ...
Dell Latitude D600 Vista System Recovery ... $18.95 - recovery-cds.com ...
Buy recovery cd according to windows version on sticker at the back of your laptop.
With recovery CD you wont need drivers.
Alternative solution is downloading drivers posted by Maanita after installing Windows from a generic Windows setup CD.
Aug 13, 2008 | Dell Latitude D600 Notebook
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Doesn't boot but i see the windows xx installation
Use ur xp cd and try repairing ... use the FIXBOOT command in the recovery console .... Not to worry much its just the boot.ini file which has corrupted ..
Dec 24, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
519 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
