Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
650 sub zero
How do you replace the door light switch.
  • JEFF SIEGEL May 11, 2010
    For which door?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I believe the part number is 3060140 have themm check it using your model and serial number. . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Posted on Dec 03, 2008
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 refrigerator - fan not coming on
Your on the right track. The other switch you mentioned next to the light switch is the fan switch, and yes the fan should run when its pressed. The quick way to determine which is the problem, fan or switch, is to get a multimeter, one that can test for continuity. You can buy one really cheap, $10 or so. Set the meter to continuity, and disconnect the switch you mentioned earlier. Place a lead of the meter on the two pins where the wires were connected. With the door open you should get no reading, but when its closed you should show continuity. If not the switch is bad, if so, the fan motor is bad.
May 11, 2012 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 650 - Light doesn't go on
It's either a new bulb needed or a new door switch. Try the bulb first as it's cheaper.
Sep 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
650 refrigerator door light switch
Go to Sub Zero.com and click the showroom locator on the top left of the screen. This will take you to a locator to find the authorized parts distributor for your area I beleive the part number is 3060140 . Once you have the part remove the three phillips head screws that hold the grill in place this is assuming you don't have the louvered grill. There is a grey power cord with a white quick connect seperate this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for yu life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor.
Nov 30, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 -- lights/fan not working
you can check the bulb's resistance if they still have. they could be both busted. if they have, the problem could come from thre door switch if you have mechanical door switches that controls bulbs. on the LED read outs, you could have a loose connection to the main board because if the board is not functioning well, then you should not have a cooling refrigerator.
please rate me, i hope i was able to solve your problem.
Jul 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Frozen vegtables within refrigerator (sub zero 650)
Replacing the light switch is not related to the temperature. Check the settings on your controls.
May 24, 2008 | Sub-Zero 650 / O Bottom Freezer...
Light is out in 650
Check continuity on door light switch with ohmmeter (turn off power and disconnect wire harness at switch first) Probably a second switch that turns compressor off if door open. my 690 sub zero had a bad light switch that was stuck on initially but now only works if I wiggle it. Can a person buy parts online? Some new subzeros have a fuse panel behind the compressor grill??
Just bought a used 690 and found a nice wiring diagram for a model 630 or something in a nice ziplock pouch behind the compressor grill. Look there for clues.
May 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 light won't stay on when door shut
super...sounds like the switch you're pushing is damaged. test it.
Dec 15, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
