Question about Vacuums
Hey guys ! I have (or my wife has) A KENMORE whispertone 116. When my wife is cleaning with it it will suddenly stops.She then wiggles/pulls on the cord and it starts again and the stops.I pulled the cord all the way out and it is fine.So its inside.I dont relish the thought of playing with that reel but thats probably where the problem is (you think ??) My first challenge is how to seperate thw tp and bottem half peices???
    Scholar:
  • 55 Answers
It definitely sounds like the cord winder is the problem. I can tell you how to take the machine apart, but it's just about impossible to rebuild that winder. When you take the winder apart the spring blows apart, and it's very dangerous. I won't be doing that again. lol Another option is to replace the winder and that is just not cost effective, and it will go bad again.
You could just take out the winder and wire a regular cord in it's place if you want to save the vacuum. You can tie the new cord in couple knots to keep it from pulling out of the unit.
As for taking the machine apart, you probably found the two screws under the hood. Sometimes they hide others under the hepa filter, but the really hard ones to find are under the cord retract button. You have to pop that off to access them.
Hope this helped. Good Luck
Posted on Dec 01, 2008
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
if you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Oct 05, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Whispertone powerhead handle release replacement
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whisper tome model # 116
If this uses a cogged belt, it should not fall off unless it is the wrong one. Give me the whole model #, then I can look and see what you have. The number of the power head is needed.
May 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone model 116, 29512991
unfortunatly what happens is the dirt that gets sucked up goes over the moter and ruins the motor. the fact that it lasted this long is suprising. the motor should be right behind the bag the only one that ive seen that isnt there is a kirby! I hope this helped you!
Feb 24, 2008 | Vacuums
Vacuums Logo
278 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
