Question about Kenmore Energy Star 44092 Front Load Washer
Will not drain
Yesterday my washing machine was working fine for two seperate loads, however a\on the last load it ran until it was time to drain. Now it will not drain it just makes a buzzing sound and left a big puddle of water in the machine.
  • 734 Answers
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Bosch 100 series washer will not spin or agitate
Cleaned out the drain hose from the front panel. Seems to be working fine now.
Thanks
Oct 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore 80 Series Washer is not draining. Worked fine for first wash last night, but did not drain on the second. Anything that can be done by us to check this problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | Kenmore Washing Machines
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water pouring out of my Kenmore HE3t
Teach, usually all leaks are visable. Have your husband remove the lower panel by removing the 3 #11 torxs on the bottom panel and pull down and off. Now you can see the tub drain hose and filter. First check the dispensor drawer. Remove it and check to see if you have anything blocking the inlet tube to the tub. Sometimes a seal from a fab or detergent cap blocks the entrance. When the disp. is out just reach in with a finger in front and you will feel the inlet grate. Next inspect the boot. Make sure there are no cuts or rips. Once you feel that this checks out ok, replace the disp. drawer and put the machine in the test cycle. On the left side press drain/spin. On the right side press spin speed until No spin is lit. Then press the prewash button 4 times until C:00 is displayed. Now let it do it's thing. It will fill, rotate, drain and spin. It will end with C:08 in the display. With the bottom panel off during the test, see if you can find the source of the leak. You can push cancel/drain anytime to stop the test. Catriver.
Jul 08, 2007 | Kenmore Elite 45986 Front Load Washer
My washer will not fill, it just drains stright out so the watter will ran for three hours. I just did a load the night befor and everything was fine. I did not move or disturb the washer in any way...
Candy, check the drain hose, make sure it has a air gap and that it is not down too far in the drain. Sounds like a siphoning problem....Catriver post back.
Oct 05, 2006 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
93 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
