Question about Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M std/by red light only
Red std/by light only. Will not turn on by power button or remote. Found o/c resistor R001 on power board(MPF7410 A). Replaced resistor, relay RL002 activated momentarily then same problem. Rechecked resistor, o/c again.I replaced all electrolytic caps on this board and changed resistor R001 again. I switched it on again but same thing happened. Resistor R001 opened again.Do you have any ideas what to check next?
  • 72 Answers
1st your power supply needs replaced. But you could have issues with the sustain boards and or your panel that is causing your power supply to fail. once you replace your power supply you should be able to power up the set, but if you don't get a picture then you will have to trouble shoot the sustain boards and panel.
Posted on Oct 05, 2017
3 Suggested Answers
  • 191 Answers
SOURCE: AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
hi isolate ur power unit out replece ur resisitor & every other burnt items then check the schottky diodes in the secondary side &the electrolytic capacitors if bulgge or leak. if all this are ok , power then use voltmeter to test ur output voltages if ok , unplug your inverter  & power
Posted on Nov 10, 2008
lovejoy91
  • 691 Answers
this is because R001 is not 5.6 ohms, it's 560K ohms
Posted on Jan 11, 2011
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
My Akai pdp4225m does not turn one green light is on but no pic or sound..There is a double clicking sound when I try and turn it on also when it does work it shuts off after and hour or so..Any info would...
Power supply filter capacitors and smoothing capacitors have warped. There will be some bad FET's, Diodes, and pull-up resistors too that need replacing. You can send us the board and we can repair it for you if you like.....
Your having a DC switching and regulation problem, its very common in these Akai models. I have repaired over 800 Akai LCD tv's so far since 2006. they all seem to have had the same fault scenario related to a similar problem like the one your having....
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Oct 29, 2009 | Akai PDP4225M 42 in. Plasma Television
Akai TV troubleshooting
power supply problem or screen needs re-gasing or another board fault call up manufactuer and request repair as it will still be under warrenty
Jan 17, 2009 | Akai PDP4225M 42 in. Plasma Television
MY BLACK COLORS ARE RED
steenson
To be honest with you. Do not waste your time change the main input board, your problem is solved. Because the main input board coul be defective. I can help you get the input board. Please, my e-mail Stevebuy31@hotmail.com
Dec 10, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M red std/by light on
Stevenson
There is a difference between diodes and capacitors. The role of a diode is to rectify and some cases regulate voltages. Meanwhile, a capacitor is there to hold charges. Back to your question, to check an schottky diode, you need an ohmeter with a diode symbol, the reading starts like this .500, .600, .300. 125. still consider good forward bias. .1200 or infinite reverse bias is consider good still. But it shows 0 continuity then that diode is bad. You can also use ohm's law, resistance to also check a diode. Please e-mail me if you some further lesson at Stevebuy31@hotmail.com
Dec 01, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai 42 plasma controller can not be programed tried every code
i just had this same problem with my 42" akai plasma and after getting no help no where i finally figured it out on my own. The model i have is a PDP42Z5TA but my guess it will work with yours also.if your remote is like mine there should be a "set" button somewhere up at the the top.hold this down till the "tv" button goes solid red. with the tv on or off keep pressing the power button till the tv turns on or off( dont go too fast) or you can pass it up easily cause when the tv does turn on or off you have to hit enter to lock it in.
Nov 12, 2008 | Akai PDP4225M 42 in. Plasma Television
Nov 10, 2008 | Akai PDP4225M 42 in. Plasma Television
Nov 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai Lcd TV
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
If you need further assistance or to get the power supply repair, write to jah2mil@hotmail.com
Nov 07, 2008 | Akai LCT2701TD Television
Akai PDP4225M 42 in. Plasma Television Logo
60 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
