Question about GE JVM1440 Microwave Oven
Touch pad works on some buttons some does not
Ge jvm1440bh04 spacesaver undercounter micro with vent
  • 78 Answers
Replace the touch pad.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Nov 30, 2008
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Touchpad is not working
    Hello :
    If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
    Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
    Place window mesh over vent to keep insects out.
    good luck .
    please rate !
    Mar 29, 2010 | GE Microwave Ovens
    Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
    sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
    Jan 18, 2010 | Samsung Microwave Ovens
    Heat doesn't come on in microwave
    If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
    May 01, 2009 | Microwave Ovens
    GE microwave not heating lights and keypad functional
    You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
    Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    GE JVM1440 Microwave Oven Logo
    145 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
