Question about Starbucks Saeco Italia Digital Barista Coffee Machine
No water through the dispenser
A visiting family member poured water into the bean grinder. I cleaned and dryed it out. I even took apart the brew unit and cleaned the filters, etc. It was making coffee afterward then stopped dispensing coffee thru the dispenser. The hot water wand works fine but still no water through unit. It grindsthe coffee perfectly, then dumps the dry ground coffee into the grounds contrainer in the tray. Help!
I am thinking about sending it back to Ohio for repair but saw you knew of location in DC area for service. I live the the Fairfax, Va area. Where is there an authorized service center to take my digital italia machine?
D in Fairfax
  • 29 Answers
Http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this link if it cant help u fix the problem it can direct u to someone who can
Posted on Feb 27, 2009
Saeco Grind and Brew model IDR 008 TG first the grounds were backing up and door not opening to go into basket, cleaned the dispenser per directions.. now the beans do not even grind at all nothing is...
Your grinder needs cleaning- maybe oily beans got used and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out. ----------- The powder from the coffee grounds seems to get caked in the grinder. The only way to get it out is to run hot water into the little opening where the grounds funnel into the filter basket. --------- This will help.Thanks.Helpmech.
Aug 25, 2011 | Saeco Vacuums
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
Grinder is not functioning, apparently, resultant brew is between tan and clear.
HOw oily are the beans you are using ? cause oily beans will clogg up the grinder causing none or little to come out. Try running some really dry beans threw decaf beans are generally drier than most. If the amount of coffeee being ground doesnt increase then the grinder will have to be taken apart and cleaned out.
Dec 17, 2009 | Saeco Talea Giro Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
217 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
