I do not have a color picture
I just moved my TV and I cant find the remote, I currently do not have a color picture, what can I do to fix the problem without the remote?
  • 28 Answers
If you had a color picture before moving the TV, then you should check the inputs. Make sure all the cabling is properly and securely attached.
If this does not help, please provide more information, such as a description of the TV, indicate whether the TV had a color picture immediately before moving it, and whether you have reason to think that there is a mode for black&white.
Posted on Nov 30, 2008
I have telefunken tv and whene i start it the picture come but it block i cant move anything i cant use the remote i cant even close the tv just if i Unplug the power pls helpe me
I'm not quite understanding what exactly you are saying. Do you mean,
You have a TV, and when you turn it on, you have pictures but, you can't scroll or operate/change channels, volumes etc. by using the remote but, in order to turn the TV off, you have to unplug the power cord.
1. Check the battery in the remote
2. If the battery is good in the remote then you might have a bad remote, buy new remote or replace it with a universal remote.
3. If either not a battery or remote, then it will be the control board inside the TV quit working and will need to be replaced. Depending on how expensive or age of the TV. By the time you invest fixing the board with labor, might runs you from $200 to $400 bucks, and you can buy a new TV from Walmart a 49" inch TV for $319 bucks.
Jul 30, 2018 | Televison & Video
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Picture on screen shrunk to about half size and color bands go around the picture - red, yellow, green, blue - almost looks like things are in 3D
  • Screen looks 3D
Mar 22, 2010 | Apex Digital GB43HD09 43" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
The colors on my tv have separated, red, blue and green.
This a convergence problem. You maybe able to correct "electronically" by using the remote control and menu setup options. If you cant get where you need to go via remote control. A profession tweak may be needed inside the tv to phyiscally align the colors. good luck
Jun 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
48" rear projection hazy/bad picture
most fluid changes would fix that. I recommend doing all three but that's just me. Also make sure the crt's are full as this would cause the set to be out of focus. also make sure you don't move the yokes too much because you can knock the convergence out pretty bad and also have a blurred pix
Jan 09, 2009 | Televison & Video
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Televison & Video
Color convergence s fine but entire picture needs to be moved to the right
Im no pro, but sounds like your mirror is misplaced or your unit is tweeked inside. I had my tv open with convergence fixed and now I am trying to match up the colors and focus to make the picture normal. Anyone have suggestions I would appreciate it also. Good luck!
May 24, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
