Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Video Head cleaning
My Camera is asking for me to clean the video head.
I have bought a video head cleaning tape and have used it before with success.
However now, after following the instructiions given with the tape, the camera is still asking for the video head to be cleaned.
I have repeated the process but it hasnt worked.
i havent rewound the tape or anything and have just gone by the instructions.
does the video head need replacing or something?
    Top Expert:
  • Sony Master
  • 12,962 Answers
Tape is by itself also abrasive so you might just try running a long length tape from the beginning to the end to see if that does the trick. If that does not do it then you either have a badly clogged video head or a bad unit. You might also want to consider using Carbon tet or equivalent chemical on head assembly.
Posted on Jun 14, 2017
silly girl
  • 513 Answers
SOURCE: Tape Cleaning on-screen warning
Have you tried using a different tape? Try using a sony tape if you've been trying with another brand. Sometimes they work only with their own, and it can just kick in. Could also have something to do with the battery. Try replacing. Do not let your Li-Ion batteries run all the way down before charging and do not charge them fully and let them sit idle. both of these things kill these types of batteries. Hope it helps
Posted on Apr 02, 2006
welcomejee
  • 10594 Answers
SOURCE: Bad video head!! How does it get fixed??
Here is an option....use " Hammer " and fix the Rest Of Camera.
Posted on Jul 30, 2008
renx
  • 71 Answers
SOURCE: Cannot find a head cleaner for Sony Digital 8 (DCR-TRV460)
Yes you can clean the heads. It's a delicate procedure, but, requires no disassembly. But, I'm curious about your mention of "blurry spots." Typically, on a digital camera, the video when the heads are dirty, will either just appear as a white screen, or, will come out blocky and glitchy (like poor satellite reception). "Blurry" would result from a dirty lense or filter. However, to clean your heads, I would run to Radio Shack and buy cleaning fluid refils. Take a Qtip and dampen it with the cleaning fluid. Open the camera, remove the tape and look for the video drum. Lightly rub the Qtip along the drum horizontal to the spin direction (not across the grain). Turn the drum and clean until you have swept the entire circumference.
Posted on May 02, 2009
ripleymojica
  • 643 Answers
SOURCE: Sony Handycam DCR-HC38 is rejecting the head cleaning tape
camera has bad tape loader and or bad tape sensors. sounds drastic but bang it a few times with the palm of your hand. if this doesnt work contact sony service center
Posted on Jun 01, 2009
  • 29 Answers
SOURCE: sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Posted on Jan 12, 2010
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Camcorder always says cleaning cassettewhen trying to record
Either video head is dirty/ clogged or broken when camcorder issue head cleaning warning.
Please use good quality video head cleaning tape to clean video head and if problem still exist, take camera in for video head replacement.
Thanks.
Aug 17, 2009 | Sony Video Cameras
SONY TRV35E CLEANING
Put video head cleaning tape in camera and press play (as per instruction of tape) to clean video head.
Click HERE to see an image and price info of Video-8 Head Cleaning Tape.
May 08, 2009 | Sony Handycam CCD-TRV35E Camcorder
Head cleaning
Use good quality video head cleaning cassette as camera gives error if use improper or very old tape.
Jan 11, 2009 | Sony HVR-Z1 Mini DV Digital Camcorder
Audio problems
Video head is dirty/ clogged, use good quality head cleaning cassette. If problem still exist, go to nearest Sony repair shop, they will use Lapping tape to clean head.
May 31, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
May 31, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
My cat peed on the tape, i put it in camera went nuts. took it out, cleaned the tape, cleaned the heads,  now only plays blue on another tape where i know there is picture.  what can i do to use the...
Use video head cleaning cassette to clean camera's video heads. I also suggest you not to use this dirty cassette any more because it will clogge again camera video heads.
May 30, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
Head cleaning.
same problem in SHARP camcorders.
SHARP offers no satisfactory solutions.
Possible SHARP does not even manufacture a head cleaning tape.
If they do it is TOP SECRET.
I will never buy SHARP again.
Dec 22, 2007 | Panasonic PV-GS250 Mini DV Digital...
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Mini dv camcorder sony
the video head of your camera is dirty or need for replacement...but first clean the head using a blank new tape,don't use a cleaning cassette cause is too rough for the head just think using a sandpaper to the head what would happen it ruin the head...just forward the whole tape then play the recorded tape...5 times as it needed...if nothing change then it time replace the video head....
Aug 28, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
