Question about Sony KDF-E55A20 55 in. LCD Television
Tv shuts down (no visual or audio) then back on again
I have a Sony KDF-E55A20 LCD 55 in. It seems to turn itself off for about a minute or two, then visual is restored followed by audio a few seconds later. It has been slowly increasing to couple times an hour. The lamp light is not flashing, the light doesn't seem low, and we've had it for maybe two years with no problems.
  • 13 more comments
  • bigbonana Nov 30, 2008
    No, not yet.
  • jason41779 Dec 02, 2008
    Same problem. Need help
  • wfm1959 Dec 04, 2008
    Same problem-Picture is fine otherwise
  • Anonymous Dec 06, 2008
    I have had my Sony  Bravia for about five months.  I have noticed on several occasions that it goes completely black, and after ten to fifteen seconds, "wakes up" such as on a computer monitor that sleeps if not used for a period of time.
  • dherrera968 Dec 09, 2008
    I have the same problem. It goes black and the audio goes away then it slowly comes back on its own. But the lamp indicator is not on, you still think it is the lamp. Others I have talked to state if it was then the light would be on? I would hate to spend so much and it was only the lamp.
  • cheryl6524 Dec 09, 2008
    My kdfe55as20 looses picture for approx 20 seconds then comes back on for 30sec to 1 minute then repeats over and over...I never loose audio but it is so frustrating when trying to watch a show...
  • dsstep Dec 11, 2008
    Same problem. It has been geeting more and more frequent. The green power light still stays solid green with no other indicators lighting up to show a problem. Sony online tech support was less than helpful, after an hour of basic "trobleshooting for idiots" all they said was it needs service. No indication that it could be a weak lamp or anything.
  • sonygadgets Dec 20, 2008
    Exact same issue. Sony help was helpless. Service call is the next step. If any one has a fix please post.
  • wjordan Dec 22, 2008
    Tv shuts down (no visual or audio) then back on. Green power LED stays on constant throughout.
    Should I spend $200 on a new lamp?
  • hobes001 Jan 07, 2009
    I have the same issue with my TV turning off for about one min. and will make a soft weaning nose, then picture comes on and sound a few sec. later.  It does it after an hr or more of watching.
    Is the new lamp the fix to this problem, I do not see a clear answer yet.
  • tlilrascal Jan 19, 2009
    I have the same problem. Has anyone changed out their lamp yet?
  • customstar Jan 20, 2009
    I have the same problem. The fan is working, light goes off and on every couple of minutes, It started doing it a few time every day or so. A red light did come on once and it was a steady light. After turning the TV on again, the light disappeared. Light has been in the TV for 2 years. It is dimmer than new bu no where near being dark.
  • bigbonana Jan 25, 2009
    I had the same problem. I installed the new bulb i got on EBAY for $125- original, not imitation and it came with a one year guarantee! It is an XL-2200. Sony sells them for twice as much. Anyway, haven't had a problem since, and noticed the difference immediately as far as brightness goes- i hadn't realized it was so dim...
  • wallass00 Feb 02, 2009
    My tv will work for about 5 minutes and shut itself down, with the green light staying on. I will then turn the tv off then back on again, will work for another minute and then shut itself off again. So you are thinking that this is the lamp??? Is it easy to install and come with instructions to install.
  • ilker9361 Feb 12, 2009
    I have had the same problem now for a few weeks, tv shuts off then gradually turns back on. Now it wont stay on for more than 1 min. I'm will try changing the lamp first and if that does not work, what else could it be?
I had the same problem. I found that the exhaust/cooling fan was not functioning. I clean it and pressure air clean it. This fan needs to be on when TV is ON and also stays on, for a few minutes after the TV is turn off.
Posted on Mar 03, 2009
I had same problem......I read about it and phoned about it. Trust me it is the bulb.
I installed new one today and she works flawlessly again.
I picked up my bulb on EBAY for 109$ US with free shipping..check them out, it is a XL-2200
Sony sells them for 229.
Posted on Jan 25, 2009
  • 10,594 Answers
Symptom shows that Lamp is weak in result and needs to be replaced.
Have you replaced its Lamp yet?
Posted on Nov 30, 2008
  • Shahid Electronics
    Shahid Electronics Nov 30, 2008
    Then replace Lamp and get Sony genuine Lamp from Sony Accessories on $200 approx.
    Lamp part number is as follows...
    A1085447A
    LAMP BLOCK ASSY XL-2200U
    Please write model number of tv is search box and see details.
    Thank you.
    Shahid Electronics Dec 02, 2008
    Jason41779
    If problem is same then solution is same too :)
Took the advice posted on here and bought a new bulb.It fixed the problem and I did not realize how much my picture had dimmed before I replaced the bulb---Thanx all !!
The lamp timer needs to be reset. I found my answer here:http://www.agoraquest.com/forum.php and reset the timer. It has not shut off since.
Posted on Feb 16, 2009
I had the same issue and replaced the bulb for 130.00 withouth the casing. Problem soved. Will cost about 200.00 with casing.
Sound problem on Sony KDF-E55A20 LCD tv
Check audio output section, It sounds that the audio output IC has damaged.
May 31, 2012 | Sony KDF-E55A20 55 in. LCD Television
After set is turned on for 1 - 2 minutes the TV shuts down, no blinking lights just goes out. After a couple minutes it turns back on then goes off again.
It is symptom of dying lamp in tv, replace lamp of tv to solve this problem.
Please note that lamp has not been dead or broken yet but become weak in result and causing problem.
Lamp replacement procedure is written in user manual and it is easy. Please buy Sony original lamp for good picture.
Thanks.
Jan 05, 2011 | Sony KDF-E55A20 55 in. LCD Television
My sony bravia went through a period of switching itself off and back on again. I watched a video to see if it was the aerial and it seems better. I also pushed all the chords in but don't think that was...
If its Sony KDF-E55A20 tv then replace lamp as symptom shows lamp is near to end of its working life span and causing that problem.
Let me know if you need further help.
Aug 22, 2010 | Sony KDF-E55A20 55 in. LCD Television
Screen turns off and on Sony KDF E55A20
It is symptom of dying lamp and tv requires new lamp.
Existing lamp in tv has reached to end of its life span and causing that problem. If lamp has not been replaced in last 2-3 years, just put new lamp in tv to get it back in business.
Thanks.
Jul 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Bulb keeps going on and off . does that mean the bulb is going bad
If TV shuts off and turns On itself again then yes, bulb in TV is weak and need to be replaced.
Please buy Sony oirignal bulb/ lamp for your TV safety.
Lamp/ bulb replacement procedure would be written in user manual.
Thanks.
Jan 01, 2010 | Sony KDF-E55A20 55 in. LCD Television
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
PICTURE AND SOUND ON AND OFF
How old is this TV and have you replaced its Lamp during that time?
Symptoms shows your Sony KDF-E55A20 TV's lamp is weak and need to be replaced.
Lamp replacement procedure is written in its user manual and if you want online copy, let me know.
Aug 30, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV screen goes on and off about every two to three minutes. Lamp shuts down
When did you replaced lamp last time in TV?
Seems lamp is weak in your TV and requires replacement.
Jul 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Nov 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
431 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
