Question about Insignia IS-LCDTV32 32 in. Television
No Non-Hd sound
Brand new tv has great picture and sound but no sound on NON HD channels. No one seems to know why. Same problem, but I am on Verizon FIOS.  Verizon has no clue, Insignia has no answer either.  I can use component cables, but then there is no HD picture.  I also attached an older Insignia HD flat screen and it works perfectly on all channels.  My assumption is that the TV software in the new set is different and that everything may start working in February.  But without a solution, it is probably best to return the TV.
  • 2 more comments
  • SandyNJ Nov 30, 2008
    On my other HD TV's it has always been sufficient to use the HDMI cable without any other audio leads.  If I use component cables with the HDMI cable then I have to switch back and forth on the set between AVI and HDMI.  I also hooked up the new TV with an analogue box and regular coax as an experiment and everything works properly, without HD pictures, of course.
  • SandyNJ Dec 13, 2008
    The Geek squad TV man arrived yesterday and insisted that the TV was fine and the Verizon Digital box was the problem.  Switching to a second digital box and having the same problem didn't convince him that it might be the TV.  I then attached a second Insignia TV to the box with the HDMI cable and it works perfectly.  They suggested swapping the motherboard, but I explained that we did this when I exchanged the TV for another.  I made one last call to Insignia and they said that it is probably the TV and they would create some sort of alert that they send to stores.
    Returned the TV yesterday, replaced it with another brand and everything works perfectly.  This all remionds me of the old days when programmers blamed the hardware, and the hardware vendors blamed the software.
  • Anonymous Jan 15, 2009
    no sound on the non hd channels with the insiginia 26in. dvd set. its not the box its not the tv What gives?
  • Anonymous Jan 18, 2009
    its only picking up HD channels with sound. on the other hand its not picking up any analog channels with volume.
  • 4 Answers
No Non-Hd sound - a2d70c9.jpgDid you remember to put audio leads in
Posted on Nov 30, 2008
Pixilization on non hd channels with hdmi cable connected to HDPVR receive. HD channels come in crystal clear, non hd channels are all bitmapped and horrible
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Nov 03, 2009 | LG 42LG30 42 in. LCD HDTV
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No sound for HD channels Denon 2307
Need more detail - What is your TV source (directv, cable, etc,) Also - how is it connected to the Denon?
Apr 01, 2009 | Denon AVR-2307Ci Receiver
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Best Buy owns some of the brands it sells. Best Buy currently has five private labels which include Insignia, Dynex, Init, Geek Squad, and Rocketfish. Insignia focuses on electronic equipment, including televisions, monitors, car stereos, home theater systems, and portable video and audio players.
The Best Buy televisions are made with substandard components. They are not produced with the same standard the orginal manufacture items.
With the factor of substandard pieces and flash/firmware glitches; it sound like you have a software problem.
I would contact the manufacture ASAP and have a field tech come by to update your television.
Jan 21, 2009 | Insignia LCDTV26 26 in. Television
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Insignia IS-LCDTV32 32 in. Television Logo
368 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
