Question about Jenn-Air JGC8430 Gas Cooktop
Spark igniter doesn't arc
Everything looks clean. A spark can be visualized when turned on but the spark doesn't arc across to the opposing metal ring to ignite the gas. Gas is clearly on. Would really appreciate your thoughts on how to fix.
  • Anonymous Mar 25, 2014
    three other rings work used it awhile before then went to use again and it wont spark
    Novelist:
  • 222 Answers
Hi im gerbee fr.phil, much better to replace the part(igniter wire) coz that part cannot be repairable dont try to repair coz more dificult problem if u repair.to replace the part dismantle the unit or remove all the screw at the top of ur cooktop.before that unplug the unit fot ur safety.buy the part from the brand u carry.tnx i hope i help u
Posted on Dec 02, 2008
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Igniters works, gas may take up to 30 seconds to allow ignition
if you mean that there is gas comining out and it takes time before the gas ignites then check that the electrodes are not broken as this will allow the spark to go to earth and the gas will have to 'chase' the spark, not advised as the gas could build up and be a potential hazard. remove the top of the gas rings and make sure that they are clean, also clean the metal part with a brillow pad or wire wool to increase the chance of the spark reaching its designated point, ie. closer to to the gas thus ignition will(should) be almost instant. hope this helps.
Apr 07, 2010 | GE Profile JGP636 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Whirlpool stove top- two problems. 1) burner is not burning hot, low flame 2) igniter on different burner doesnt work, no spark at that burner.
Hi
If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like. If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Whirlpool GLT3615 Gas Cooktop
Jenn-Air JGC8430 Gas Cooktop Logo
176 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
