If the socket you plug into is loose, there is likely a broken wire or a broken solder joint or board. It is not beyond the abilities of those who have some mechanical ability. Just have some patience, do not force anything, and if you have a doubt how things might go back together- take lots of pictures that show details and placements.
SOURCE: guitar amp no sound or lighting
Ah yes: complete catastrophe. Usually when everything is not working, it is a single reason and when that single reason is fixed, so is the amp.
Based on what you tell me, I am going to say you have a bad power tube. And I will even go as far to say that you buy a set of tubes and play on them as long as you can. If so, then you not only burned up the tube, but weakened the power section and may have a slooow tube frier. I always tell customers: modern tubes have an effective life of less that 1200 or so hours and that varies. Replace the tubes once per year if you gig with the amp: period. Otherwise, guys like me (doing repairs) stay busy and the tube companies get rich selling tubes to amps with weakened power sections.
It sounds like you burned a power tube and blew a fuse. First, you need a new set of power tubes and some extra fuses (go to Radio Shack and set the value you need in SLOW BLOW fuses).
Then, replace all the power tubes. Don't worry about biasing yet, we are just seeing if there is a problem. Next, replace the fuse.
Turn on the amp and play on it at various volumes and settings. If all is well, take the amp to a tech and get it rebiased. If you can afford it, pay to have the grid/plate and other resistors changed so the power section will be like new (clean slate with new tubes). Your amp will love you for it.
Almost all of the amps I have worked on for performance problems (cant keep tubes to stay alive for very long) are directly related to end user use. When you use a tube until it blows it ALWAYS TAKES SOMETHING WITH THE TUBE WHEN IT GOES (like the power section components). The compents will be weakened and the tubes will 'wear' at different rates that can even move them out of the 20% tolerence they must be within to sound good. 99% of the time a board repair with a retube after a catastrophe fixes the amp until the next time it is 'run into the ground'. Tube amps are NOT invinceble: they are weak compared to solid state and expensive to own. But we love tubes because they sound great. I have solid state to knock around on, when when it counts, I play only with tubes. I have spent hundreds on good tubes because you do get what you pay for.
Hope this helps!
-mike
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
SOURCE: NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
SOURCE: Crate GX-20M burned resistor + popped cap values?
go to
http://www.crateamps.com/support/index.php
you may find what you are looking for there.
SOURCE: looking for a circuit board manual or diagram for
try the Crate Website
http://www.crateamps.com/support/discontinued.phprate
