Question about Brother HL-2170W Laser Printer
Toner light is still on - Brother HL-2170W Laser Printer
If you put new toner in your used cartridge and you still have the Toner light, you need to reset the "reset gears". Take the cover off of the gear side of the cartridge. The reset gears are actually attached to the inside of the cover. Move the gear with the lever to the opposite side of the current position.
Posted on Mar 30, 2010
    New Friend:
Actually, I succeed BUT only after leaving the front case opened
1)Open the front case (generates error message & red light), turn off machine.
2)Leave the front case opened, then hold down main blue/button "Contact" while switching on power button (facing machine, on rear right)--
3)Release it when all the three LEDs (Toner, Drum, Error) are lit.
4)Press 2 times
5)Press 7 times
Note that at each time you press (4th and 5th), the button-contact lights up.
Black tape on right side of CARTRIDGE worked for me too. Thanks for the tip!! This saved me money and a last minute trip to Micro Center.I agree with MCline, "I can SEE when I need a new toner cartridge; I don't need the printer telling me when it's time to change AND REFUSING TO PRINT UNTIL I DO." Shame on you Brother!!I think my next printers will be HP. I like the ability to disable toner monitoring.I am thinking of placing black tape on the cartridges of all my other Brother laser printers to manually disable toner monitoring. There is nothing wrong with applying this fix long term.However if you want to know more about this visit this website https://www.microtonersupplies.com.au/toner/brother-toner-catridges
Posted on Jul 21, 2017
I called Brother tech support. There is a sequence of pushes on the start button with the cover open that will reset the toner count. There is some internal count in the printer. When a new Brother toner cartridge is installed that count should be reset. Brother is attempting to enforce "Brother only" cartridge use by doing this. (Talk about "Big Brother"). I am hesitant to give the button sequence. I don't want to be responsible for any damage to anyones computer. So call Brother tech support (1-877-BROTHER), stay on hold for about 2 days, and then they will walk you through the button push sequence to reset the toner count in the printer. Just make sure that you have a genuine Brother toner cartridge in front of you. They will want the bar code number off the toner cartridge.
Posted on Apr 03, 2009
  • Brother Master
  • 4,338 Answers
Have you replaced the toner cartridge?
If the Toner LED is on:
Check to see if the drum unit assembly is installed correctly. If not, take the drum unit out of the machine and put it back in.
If the drum unit assembly is correctly installed, and still the Toner LED is on, the toner cartridge is empty. Replace the toner cartridge with a new one.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 30, 2008
Sharp Ar-5516 toner light problem continue blinking
If the toner light has a line under it your waste toner container is full and needs to be emptied.
May 04, 2016 | Sharp Office Equipment & Supplies
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
LIGHT COPIES WITH A NEW TONER CARTRIAGE
Was the toner sign on when u replace the toner bottle?
Dec 02, 2013 | Savin Compatible Copier Toner Black For...
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Have a problem with a Sharp AR152. The toner
Once the toner lite comes on it blows the chip in the toner cartridge, a new toner will fix your problem.
May 04, 2009 | Office Equipment & Supplies
Toner out light
Open an close the front door on the machine a few times and it will add enough toner to extinguish the toner add light.
Feb 17, 2009 | Canon ImageRUNNER 1670F Copier
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Toner light on replaced toner
probably broken toner motorshaft remove toner cartridge look to back of machine if you find a white collar and a spring laying on the bottom thats it
Mar 21, 2008 | Sharp AL 1631 Copier
Brother HL-2170W Laser Printer Logo
5,556 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
