Question about Zanussi Washing Machines
Zanussi FLS 1183 W Door Catch Broken. Is there anything I can do myself here, or do I have to call in a repair man?
    Scholar:
  • 131 Answers
Http://www.keepingupappliances.com/cgi-bin/ss000001.pl?page=search&SS=fls1183&ACTION=Go!&PR=-1&TB=A
you can order your part at the above address.it should be fairly simple to replace.hope this helps.hope this helps.thanx for using fix-ya!!!
Posted on Nov 30, 2008
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
My Zanussi fls 1183 is not washing the clothes, they are not completely wet and are not clean
This usually means that the drum is not rotating during wash or spin.
If this is the case the most common causes are a broken drive belt or the motor brushes worn out
Always remove the plug before investigating
Jan 22, 2011 | Zanussi Washing Machines
Zanussi aquatic FLS 674 C manual
I need zanussi aquatic FLS 674 C manual and I want to know the number of its belt. thank you
Dec 29, 2009 | Zanussi Washing Machines
Door wont stay closed
Either the door catch or spring is broken, or the door lock is not working
The parts are fairly easy to fit,once you have determined what part or parts you require.
Hope this helps.
Dec 15, 2009 | Zanussi F1045W Front Load Washer
Got a zanussi FLS 1186 Washing M/c Nothing happens only drain pump runs. What ddo you think the problem is
Sometihing is stopped up or the pump is damaged...either way it maybe better to have a service man look at it since it wouldn't be something easy to handle.
Oct 29, 2009 | Washing Machines
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
I think the bearings have gone on my zanussi aquacycle fls 1183w. can i do this myself, or do i need a new machine.
I have just done this myself and to be honest it was quite easy.
you will need bearings l replaced both front and rear as the cost of each was nothing, a new bearing seal and a drum gasket as the drum has to come apart.
Tools are a digital camera ,socket set, torx key set, set of spanners a cold chisel and a hammer. And you need the old bearings to put the new ones in
Jun 06, 2009 | Zanussi ZWF1420W Front Load Washer
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
Broken interior Door catch
You should open machine's upper panel (release 2 screws in the machine's back and slide the cover out) and then you will have an access to it. You should buy a new door catch and replace the broken one. Be aware that you should disconnect machine's power cable before doing it. Good luck
May 09, 2006 | Zanussi WJD1457W Front Load Washer / Dryer
Washing Machines Logo
163 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
