Question about Bose Lifestyle 28 System
Black and White instead of color
We reconnected our BOSE system as we moved TV from one side of room to other. Now it is Black and White. When we connect without Bose it is color and video games are color. How do we reset to color?
Make sure both S-video (black round connector) and Composite video (yellow connector) are connected to video outputs not inputs. It can also be the S-video is disconected, that will give you a black and white picture. FR
Posted on Dec 20, 2008
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
Peter
May 15, 2010 | Bose Lifestyle 38 System
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
Apr 25, 2010 | Bose 3·2·1 II System
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
Dec 07, 2008 | Bose Lifestyle 48 System
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose 3 2 1 GSX System
The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Nov 03, 2008 | Sony KP-51WS500 51" Rear Projection...
Dvd is showing black and white
You are running in the wrong format.
If you are in the USA then you need to set the Bose system to NTSC. If you are in another part of the globe then set it to PAL.
The other thing is to make sure your TV is set the correct way as well. The only other thing that will cause this is if you are trying to playback a PAL dvd on an NTSC system (and the other way around of course)
All the options you need will be in the setup menus for both the TV and Bose.
Hope that helps
That should solve your problems.
Jan 21, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Can only get black and white images when playing DVD's
Check your settings - video format. It should be NTSC for USA standard. If it is set to European (PAL) it will be in black & white. Hope this helps.
Jul 27, 2007 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose Lifestyle 28 System Logo
279 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
