Question about DE-1765 Radar Detector
Whistler de-1765 I have the compass combo, but for some reason, the compass is never working, it always says N,NE,or NW.....even when im going south...how do i fix that! i have tried leveling it out and everything, still....nothing works....HELP ME!
  • 3 Answers
I once owned a PNI Radar detector with a compass feature. Mine had to be calibrated by actually driving in clockwise and then counter-clockwise circled (three times each if I recall correctly. Check your manual for a similiar procedure. If you can find one, pick up a Uniden GPSRD unit. These work off the Defense Department's satellites and never need any calibration. They also track your speed from space and displays it on the detector. You can also mark locations,and get latitude/longitude information whenever you need it as well as directions to anywhere in the US. VERY COOL DEVICE! So cool, I bought one for each vehicle... however one was recently stolen.:( Hope this information helps you out.
Posted on Feb 09, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Compass not working on 2006 Mercury Grand Marquis
Electronic Compass The compass display and module are contained in the overhead console and are replaced as an assembly. For additional information, refer to Section 501-12 . The compass display can be turned off and on by pressing the MODE button in the overhead console. The vehicle heading is displayed as one of N, NE, E, SE, S, SW, W, or NW.
Inspection and Verification
NOTE: Press the MODE button to turn on the display.
  1. Verify the customer concern by operating the vehicle along roads of known direction to duplicate the customer concern with the compass.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Compass module
  • Central junction box (CJB) fuse 15 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the fault is not visually evident, determine the symptom and GO to Symptom Chart .
Pinpoint Test A: The Compass Is Inaccurate/Inoperative
Normal Operation The compass receives battery voltage from the central junction box (CJB) through circuit 964 (DB/LG). Ground for the compass is supplied through circuit 676 (PK/OG).
    Possible Causes
  • fuse
  • circuit 676 (PK/OG) open
  • circuit 964 (DB/LG) open or short to ground
  • compass zone setting
  • compass calibration
  • compass module
PINPOINT TEST A: THE COMPASS IS INACCURATE/INOPERATIVE NOTE: Always set the zone and calibrate the compass before replacing an inaccurate compass.
NOTE: After installing a new compass, always set the zone and calibrate.
Test Step Result / Action to Take A1 CHECK THE OVERHEAD COMPASS DISPLAY
  • Key in ON position.
  • Check the overhead display.
  • Does the overhead compass display remain on after prove out?
Yes
GO to A3 .
No
GO to A2 . A2 CHECK THE COMPASS MODE
  • Press and release the SELECT switch on the overhead console.
  • Does the overhead compass display turn on?
Yes
If the compass display turns on correctly, GO to A3 . If the compass display turns on, but the heading is inoperative/inaccurate or the display indicates VAR, GO to A4 . If the compass display turns on, but it does not display all directions, or indicates CAL, GO to A5 .
No
GO to A7 . A3 CHECK THE COMPASS DIMMING
  • Turn the headlamp switch to the parking lamps ON position.
  • Does the compass display dim?
Yes
TURN the headlamp switch to the OFF position. GO to A4 .
No
TURN the headlamp switch to the OFF position. GO to A8 . A4 CHECK THE COMPASS ZONE SETTING
  • Set the compass to the correct zone for your location. Refer to Compass Zone Adjustment in this section.
  • Does the zone adjustment set correctly?
Yes
GO to A5 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A5 CALIBRATE THE COMPASS
  • Calibrate the compass. Refer to Compass Calibration in this section.
  • Is the compass calibrated correctly?
Yes
GO to A6 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A6 CHECK THE COMPASS ACCURACY
  • Position the vehicle at each of the 8 directions (N, NE, E, SE, S, SW, W, NW) and verify that the displayed heading is accurate. The vehicle must be stationary for at least 10 seconds at each direction.
  • Is the compass display accurate in each direction?
Yes
The compass is OK. REVIEW the operation of the compass with the customer.
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A7 CHECK THE VOLTAGE SUPPLY TO THE OVERHEAD CONSOLE
  • Key in OFF position.
  • Disconnect: Overhead Console C930.
  • Measure the voltage between the overhead console C930-1, circuit 964 (DB/LG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
TURN the key to the OFF position. GO to A9 .
No
VERIFY the CJB fuse 15 (7.5A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. A8 CHECK THE DIMMING CIRCUIT
  • Measure the voltage between the overhead console C930-4, circuit 484 (OG/BK), harness side and ground while rotating the instrument panel dimmer switch.
  • Does the voltage vary between 0 and 10 volts?
Yes
GO to A9 .
No
REFER to Section 413-00 for further diagnosis of the instrument cluster and panel illumination. A9 CHECK CIRCUIT 676 (PK/OG) FOR OPEN
  • Measure the resistance between the overhead console C930-2, circuit 676 (PK/OG), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
No
Nov 30, 2017 | Mercury Grand Marquis Cars & Trucks
How can i change the time
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Apr 02, 2014 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Owners manual for whistler 1765
For manuals for Whistler Products visit their web site ( Whistler Group Inc ) or call 800-531-0004
Nov 15, 2012 | Whistler Vehicle Parts & Accessories
XTR-590, powered up plugged in, 1rst day having it, drove by 2 uconn dodge chargers and 3 state police in the course of 30 seconds and didnt hear a peep. I doubt they all had radar off? is there something...
When the unit goes through its self test - make sure the display shows either RADAR or COMBO as if it just shows COMPASS, the radar section of the unit is turned off and its basically a compass unit.
It is possible that you ran across officers that didn't have their radar guns turned on.
For more info/questions contact Whistler at 800-531-0004 or info@whistlergroup.com
Aug 10, 2011 | XTR260 Radar Detector
My detector is in compass mode. how do i put it in highway mode?
Press the Menu button and the unit should show "COMBO" if it does then the Radar and compass is turned on. If it only shows "COMPASS" then press the dark or City button to have the "COMBO" displayed. Then wait a few seconds and the unit will exit menu and save your setting.
Dec 15, 2010 | XTR695 Radar Detector
Whistler 1765 -- why does it give you all kinds of false alarms when there is no radar in the area. Also it alarms for one minuet at full signal strength for about 1 minuet then stops. Is there any way to...
Do you have another radar detector on at the same time? If so, turn the other detector off. Detectors will "talk" to each other when their on in the same vehicle?
Have you tried the unit in a differnet vehicle to see if the problem remains?
Oct 15, 2010 | DE-1765 Radar Detector
Does not sound alarm till its to late
The lower end Whistler radar detector models do not have particularly good performance against all radar gun frequencies. Whistler's XTR-690, Pro78 and XTR-695 on the other hand do perform very well against all police radar guns. Its basically a matter of you get what you pay for.
Mar 18, 2009 | DE-1793 Radar Detector
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
Whistler DE-1605 Radar Detector
go to whistler's online store www.whistlergroup.com or call 800-531-0004
Nov 11, 2007 | DE-1605 Radar Detector
DE-1765 Radar Detector Logo
160 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
fordexpert
Ngoro
Ngoro
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
