Question about Hobart D300 Stand Mixer
Need to replace a cord on a 30 quat hobart mixer and need to know where positive negative and ground go
  • 2 more comments
  • tacod69 Dec 14, 2008
    3 phase
    not sure where the ground is there are no wires attached right now so i dont have anything to go by.
    3 i think but theres no plug. there never was one when i got i
    What im looking at is inside the mixer stand at the back. There are 5 to 6 screws where the wires attach. 2 of them are connected to something inside the mixer. Each of those wires seemed to be connected to one of the other screws. and then theres one on its own that i figure is the ground.
    I tried attaching wires and pluging it in. I heard a small humm but it didnt turn on. Its been in a shed for the past few months so it was really cold when i tried. Not sure if that would make a difference.
    And thanks for your wime and assistants it is greatly appreciated.
  • tacod69 Dec 22, 2008
    i tried hooking up a cord. It made a humming sound but no action. It may be to cold out. since its in the a shed
  • 640 Answers
I need to know if the mixer is 1 or 3 phase.Look at the plug---does it have 3 or 4 prongs?
Posted on Dec 13, 2008
  • 1 more comment
  • anthony james
    anthony james Dec 14, 2008
    Make sure the green (ground) wire goes to the ground on the plug,it should be marked green.Then hook up the other 3 wires in any order---turn the mixer on,the beater should move clockwise--if not change any 2 wires and it will run the right way.Let me know.
  • anthony james
    Does the plug have 3 or 4 prongs?
  • anthony james
    anthony james Dec 15, 2008
    Is there any way you could post some pics?
Where can i find a hobart k45 replacement cord
You can purchase a replacement power cord from Amazon.com. It is part number 9701025 and includes the grounding style plug which the original did not have. It can also be purchased from your local Sears parts store but it will be much more expensive
Apr 26, 2012 | KitchenAid K45SS Classic Stand Mixer
How do I empty and then refill the grease in the gear box of my 30 quart Hobart mixer
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
May 05, 2011 | Hobart A200 Stand Mixer
My hobart n50 has no ground on the power cord, also any ideas on where to get parts?
If the ground pin on the cord is missing, you can put a new plug on the end of the cord -- hardware stores have them.
Charlie
Jan 07, 2011 | Hobart N50 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Hobart mixer 30 quart
this is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
Nov 29, 2008 | Hobart A200 Stand Mixer
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Hobart D300 Stand Mixer Logo
88 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
