Dryers Logo
Posted on Nov 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer won't run
Dryer stopped for no reason. Can hear the the motor humming when start switch is activated. Sounds like it wants to start but does'nt seem to have enough starting torque to rotate the drum. With the top panel open I can rotate the drum by hand and energize the start switch and the drum and heat work seemingly fine. I also checked the motor, belt, belt tensioner from the rear access panel and there seems to be no problem there. Do you have any suggestion? Thank you
Anonymous
Level 2:
Champion:
  • Expert 249 Answers
  • Posted on Nov 30, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
249
Questions
Helped
168000
Points
364
Power pack, or condensur is faulty that stats the motor fit new one .close says!
1helpful
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 • Dryers
My Kenmore 600 series dryer won't start when I push the start knob...I can hear a hum when the knob is pushed in but it won't start. Any suggestions?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
'lll
Aug 17, 2011 • Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
heatman101
Aug 11, 2011 • Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
My LG DLE8377WM dryer stop spinning. Turns on fine, smells as though heater element turns on but the tub won't spin. Can hear what sounds like a motor trying to turn.
heatman101
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
1helpful
2answers
Hi, I think I need a new motor. When I push on the start switch, I hear a hum, but the motor doesn't start up. However, sometimes it does start. However, sometimes after running for a few minutes, it...
something could be lodged in the blower wheel, or otherwise jammed up the unit, ie; rollers, idler wheel.
either way something has caused your motor to work harder than it was designed to, or it has just gone bad.
there is a thermal switch within the motor to shut it off if it gets to hot. that is likely the reason it shuts off after a little while and when it cools down will restart.
there is also the chance that your push to start button has gone bad, but highly unlikely.
either way it will require tearing down to find the problem.
best of luck, have fun
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
