Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Envision 9410e monitor only display for a second.
The monitor looks almost black but when select/auto button is pushed it will display for only a second.
What things can I look at.
I have read other posts that suggest replacing the capacitors, what are these?
I have been gone for 4 days and there was a power surge, I had turned off my computer but apparently forgot my monitor. Could this cause my problem? If so, I must need a better surge protector!
    Champion:
  • 293 Answers
Hi...there,
It's seems you got unlucky...your backlight inverter got burnt...Need to replaced a new one or repaired it. Caps it a fuse look like a tiny battery that power the backlight...
Posted on Dec 01, 2008
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
Envision monitor EN-7100e color is screwd up.
Unfortunately this monitor has captived VGA cable, you cannot easily replace it. Try moving the cable around to see if you will get normal color back.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001218.pdf
http://s807.photobucket.com/home/budm/allalbums
Apr 12, 2010 | Envision EN-7100e 17" Flat Panel LCD...
We have an Envision 9410e 19" LCD monitor which is about 4 years old. Recently it has started being very slow to start up, especially in the morning after the system is not in use all night. The screen...
cmgusa, Reconnect 9410e to original PC. Please note if same symptom occurs again. This sounds like an intermittant or failed solder connection of some component on the inverter/smps power supply board. Have you tried the FLASHLIGHT test when the monitor goes to a BLACK screen? You did not state the approx # of hrs of use this unit has on it. The Flashing you describe is most likely the cold-cathode-fluorescent-tubes trying to start-up. If they don't light then you get a black screen. They (CCFT) get their voltage from the inverter section of the power supply. But anyway... Your options as a consumer/user are as follows. Check with Envision to see if they have a swapout program... you send them your 9410e +$50-$90 and they send you a REFURBISHED 9410e with 30-90 day warranty. or Find local TECH (TV-Monitor) who knows forward and backwards all there is to know about repair of LCD monitors. There are some very good tech's right here on fixya that could do the repair and not rip you off. Last but not least is try to effect repair yourself. If this last option is of intrest get back to me only after doing web search of monitor disassembly video clips on youtube and doing search for things like bad caps or recapping and inverter repair + have a minimal understanding of how a SMPS/inverter powersupply functions. I'm louie12fix on fixya or lmistyrel @aol.com Bye for now.
Sep 21, 2009 | Envision 19" Widescreen Flat Panel LCD...
The monitor turns on and connects to my computer then turn off but the power stays on. any ideas?
Make sure the external VGA port on your laptop is enabled. Not all laptops automatically detect a monitor connected and turn on the port. There will be a function key somewhere on the keyboard to control the port. Location varies by manufacturer and model. The usual sequence when you press the key is: laptop display on and external VGA off, laptop off and VGA on, both on.
Apr 17, 2009 | Envision 19" Widescreen Flat Panel LCD...
MONITOR DISPLAYS OSD LOCKED
Page 5 in your users manual : 6 settings you have 45 seconds to push exit button to save. I have had times that when changing computers that I have had to disconnect the video cable, power down the monitor and computer, power up the monitor with nothing connected to re-set it, power everything down, reconnect monitor, and restart the system. Most times the H191W will detect everything If you need a manual
www.envisiondisplay.com or 1-888-838-6388 can help you. I have used this monitor for several years and think its one of the best. The technical support should help you. Hope I helped.
Mar 13, 2009 | Envision H191W Monitor
Need to Auto Adjust Envision 20" monitor every time
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Nov 09, 2008 | Proview PX-986 19" CRT Monitor
Display not centered
there are 6 buttons at the buttom of the monitor.
option 1). press the auto adjust.
option 2). from the right to left: "power","LED","Manu/enter",">"," <" ,"auto adjust"
to adjust the screen:
press manu-button, use <> button to navigate to the 3rd button on the top row.
(4way arrow). press manu again. that is going to get you into the submanu.again use the <> to navigate to H. Postion button.use the <> to mve the screen to the desire postion.
press manu again and select the right button on the button row (exit) and press manu.
Nov 06, 2008 | Envision EN-7220 17" Flat Panel LCD...
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Resolution problems following a power lock.
Turn on the on screen menu by pushing the number (1) button. Go down the menu to the memory recall function and Push the number (2) button to reset all the controls to factory settings. This should return you monitor to it normal function. If this does not solve your problem, you can call Envision customer support at this telephone number. 1-888-838-6388. They should be able to help you solve the problem. I hope this information helps you with your problem.
Jul 14, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
119 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
