Question about HP Compaq Evo Notebook N600c
Display does not expand to size of screen
When the laptop boots up the active window is only 60% of the available screen
  • Anonymous Apr 17, 2009
    I have the same problemwith Packard Bell notebook and cant find a solution. How do I know what is the right driver for my laptop? Thks
  • HP Master
  • 32,281 Answers
This problem occurs when :-
1. The screen resolution has been set too low, try setting it to 1024X768
2. The video driver is wrong.
Go to Control Panel, then Display, then Settings to check the screen resolutiuon (change if required), then Advance, then Adapters to check what video has been installed, (you may need to download the correct video driver from HP/Cpmpaq)
Posted on Nov 30, 2008
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
Frozen blue screen
Try starting the machine in safe mode: Repeatedly press F8 on startup and choose safe mode from the options window. This only loads the basic drivers so if the problem is with graphics driver for instance, the machine should boot to the desktop. If this is successful, you can uninstall the display driver from device manager: start>control panel>hardware and sound>device manager. Look for display adapters and expand the menu. Right click the adapter and uninstall.
Reboot the machine normally. You can then download and install a new driver.
Mar 29, 2012 | IBM ThinkPad 600X P3-500Mhz Laptop (T600X)...
I lost my Activation Product key. I need it for my activating my Windows Vista Starter. Please help me. Thanks.
There is two steps in installing and activation Windows.
First you need the Product Installation Key to install Windows.
After Windows is installed, Windows will requite Activation. When you boot up Windows will ask you to Activate your Windows program (you are given a 30 days to activate then Windows will lock you out).
You can activate Windows over the Internet or you can activate the Windows license using the phone. If you select the phone method you need to select your country and windows will display the phone number. Then follow the screen instructions.
Oct 28, 2010 | Computers & Internet
After it boots up and goes to the desktop the screen cuts off. the power button is still lit up but the screen is blank.
During boot up press function key F8 repeatedly until the windows boot menu appears. Select boot in safe mode. If this works make sure the correct video card is selected for the laptop. Go to your control panel click on system then select the hardware tab and click on the device manager. Select display adaptor and click on the plus symbol to expand the selection. Double click on the display adaptor and select the driver tab. Click roll back driver or uninstall the driver. Reboot your system normally. When windows prompts you to install the newly found device follow the instructions to install the graphics card driver.
If this does not work connect the laptop to an external monitor to see if you can see the video on the external monitor to find out if the graphics card is working.
Aug 13, 2010 | HP Compaq nc6000 Notebook
Pavillion dv9000 screen is gray, with external monitor connected,laptop will only start in safe mode using vista ultimate
Your display drivers could be corrupt.
Boot the machine into safe mode. Right click on Computer and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the HP support website.
Regards.
Oct 02, 2009 | HP Pavilion dv9000z Notebook
Black Screen Dell 600 Laptop
The display drivers maybe corrupt.
Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
I would be a good idea to update the display drivers via the Dell support website.
If it still won't display in normal mode please post back.
Good luck.
Sep 17, 2009 | Dell Inspiron 6000 Notebook
Can't adjust display size on monitor
1st try Fn+F7 or Fn+F8 to expand the screen.
If that doesn't work, reinstall the video driver, available a support.dell.com
May 16, 2008 | Dell Latitude D600 Notebook
DOS Screen Size
Press alt and enter key at the same time
also you can press f2 to get into the cmos
or unplug your hdrive and start this might get u in
jay
Nov 18, 2007 | Compaq Armada 3500 Notebook
CMOS??
that is the problem wid ur dos settings.......
Nov 16, 2007 | Compaq Armada 3500 Notebook
HP Compaq Evo Notebook N600c Logo
1,544 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
