Question about Sima MCM 1500 WATT POWER INVERTER
Sima 1500 fuse
Does the sima 1500 inverter have a internal fuse?
  • noguns3 Dec 10, 2008
    My fault light keeps coming on. I have hooked it up to two different batteries and cables and the thing refuses to work. Have checked all external power sources and in-line fuse and they are all good. Has to be internal. Any luck finding an answer?
We turned on our generator while our inverter was still plugged in. Can we fix it?
Probably blew either an internal fuse or a diode, open it up, take a look, what do you have to lose?
Oct 11, 2014 | Watts Cobra Cpi1575 1500w 1500 Watt Power...
Why is my inverter keep on blowing fuses?
You probably caused an internal short circuit.
Sep 15, 2014 | Electronics - Others
Where can i buy cheap travel adapters?
Take a look at Walmart. They have various plug adapter sets at good prices;
http://www.walmart.com/ip/Sima-SIP-3-Sima-International-Travel-Adapter-Plug-Set/10575435
Jan 17, 2013 | Luggage & Travel
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Where can I find a ct-2 for sale?
I found a compoable product that was available. Video Filter. Thanks
Oct 08, 2009 | Sima GoDVD CT2 Copy Master Digital Video...
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Does item have a fuse? Burned out
i have the same one ...and i'm not seeing a fuse, there may be one internally
does the inverter have strong "burnt wire" smell if so it is probably fried.
Aug 16, 2008 | Vector VEC 024 400-Watt Power Inverter...
Sima MCM 1500 WATT POWER INVERTER Logo
Top Sima Electronics - Others Experts
Are you a Sima Electronics - Other Expert? Answer questions, earn points and help others
