Question about Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sharp aquos model # LC-22SV6UM
Does this model have a built in digital tuner?
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Posted on Aug 01, 2008
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
SOURCE: Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Posted on Sep 29, 2008
  • 50 Answers
SOURCE: Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Posted on Mar 18, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
32 inch sharp aquos can't find any channels with rca amplified indoor antenna
That could be because the antenna is pointing in the wrong direction, or it's just not getting enough signal where it is in your home.
Have a look at neighbours antennae. See the direction they are pointing. Point yours in the same direction too.
Other causes: you are trying to tune the analog tuner rather than the digital tuner.
Sep 07, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
I have recently bought a sharp aquos lc 40 le811e tv set,im havin problems tuning it i have a new antenna installed and when i try and auto tune it says there is no signal,i have also tried 2 differant...
Does it have a built in digital tuner? unplug wait 5 minutes hold power button while you plug it in you should get into a secret menu usd by techs look and see if you have a digital tuner hope that way works for that set
Jan 27, 2011 | Sharp Televison & Video
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Has sharp 42 inch aqous got inbuilt digital tuner
Hi www_andremou
You are right. It has got a digital tuner. After you power on, press the Menu button on the Remote Control, select Setup. Select the Auto Installation. The Inbuilt digital Tuner will search for all the available channels r and tune automatically.
If you wish change the Volume and Screen etc
The Instruction manual gives full details.
Good Luck
luciana44
Dec 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mar 17, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Analog to digital conversion on Aquos?
Dan
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HDTV
Shouldn't have to, but HD through the wall connector may be an issue if you are wanting that. I don't know for sure. Almost all tv's made in the last 1 year - 2 years have digital tuners built in
Jun 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-22SV6U 22 in. LCD EDTV Logo
589 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
