Question about Mitsubishi VS-55707 TV
No color for first 45 minutes TV is on.
Color comes on after 45 minutes, but adjustment is limited.
  • 121 Answers
Temp sen componet need tech .  to find  comman prob solid state equip.
Posted on Nov 30, 2008
How do i adjust the color on an element tv
you will need the remote that came with the tv
in the menu it has limited control of colors an color temp.
Sep 25, 2014 | Element Electronics FLX3210 32 in. LCD TV
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
My tv has color yet my vcr/dvd player has limited
The problem may lie in any one the following things.
1. Cable you are using
2. You set your video color system properly(NTSC/PAL/Scam) You fix it only auto color
Dec 30, 2009 | Televison & Video
Tv keeps turning off
Mine was doing that and then it lost all color..tech tells me its the dmd board, a pricey repair. Debating whether it's worth it or not.
Sep 24, 2009 | Samsung DLP HL-P5663W 56" TV
Kp51ws500 color flickering
I'm afraid I don't have good news. This is known as the "Flicker Issue." As a Sony authorized servicer, the shop I worked for was directed to replace all three of the CRT's in the limited number of sets that experienced this issue. The cost per tube is typically around $200. If you decide to take this on, it is best to replace one CRT at a time, power up the set and do the yoke adjustments and electrical alignments to get the new color to line up with the existing ones.
Jun 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Feb 25, 2009 | Samsung HC-P4741W 47" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-55707 TV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
