Question about Epson Stylus 1400 InkJet Photo Printer
EPSON 1400 PRINT HEAD
I NEED 2 PRINT HEADS NEW OR REFURBISHED
Printheads on that EPSON...as almost all Epson brand printers are IMPOSIBLE to change. Are made for waste containers! It's trgough. If you can change head on that, maybe in a bit less than 200 hours! It's NOT a joke! Better, i nought a K8400 HP large format...It's 4 seconds to change heads. Also, they are cheap price and LAST very very long...but NEVER let any inkjet printer without printing all 4 colors for a minimum of 1 page in 3 weeks. Heads would dry. If you care you'll print with the K8400 for about 100,000 pages.
Posted on Nov 13, 2010
Print head alignment nozzle
Borderless print ?
Set custom page as exactly paper size. Set borderless expansion to max. Select appropriate paper media type.
Sep 29, 2013 | Epson Stylus 1400 InkJet Photo Printer
My epson black ink wont print??
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
Why does my epson 1400 feed paper straight threw instead of printing?
first, are you on a screen that has text on it to print. say a word document? Not a web page. second, how long has the 1400 been sitting before this happened? if a long time then the ink head may be clogged. Try printing in gray scale only and then in color and see if the same thing happends. Third make sure all print tasks are cleared. normally in the bottom right hand corner you will see a printer icon. if youclick it it will tell you how many jobs are waiting. clear them all. by pausing and then canceling them. (if they are there.) if none of those exist then look for the ink pad on the inside of the printer to the right. ( you will have to see if the head is moving left and right to do this.) if the printing head is moving left and right and you dont see anything stuck like paper and such in the machine then you need to find out if the black foam on the right where the print head parks when its done and shut off is wet or not. this entails watchin the print head go to the left and then shutting down power to this printer by unpluggin it. (this is not a switch off it needs to be unplugged from the 110 outlet) then if you can feel by a Q tip if you donw want to get your hands inked and see if it comes up with colors and black. if it does not then the ink heads or ink or both are dried. then do a search here on Fixya to look for clogged ink heads
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printer heads print head need serviced
Color printers do not like being unused for long periods, the print heads will become blocked.
If the color cartridges are full and you have done a deep clean print head several times, then the color print heads are most likely is blocked the print head needs to be replaced.
NOTE the cost of replacing printer head could be expensive, this could be an opportunity to upgrade to a new and better printer.
Nov 26, 2010 | Epson Stylus 1400 InkJet Photo Printer
Describe your Epson Photo 1400 Stylus printingProblem I have lines appearing on My prints, I have cleaned and re aligned the print heads but no joy
: i'mma having problem with my epson 1400 it keep on having horizontal line on the picture after in clean the head and align it
May 16, 2010 | Epson Stylus 1400 InkJet Photo Printer
Lines in the prints. using all new ink cartridges
You might try running the print head cleaning step a few times. It does waste a bit of ink, but this is the only way this is going to get resolved shy of replacing the heads and or printer. good luck
May 04, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 stopped printing after syringe windex method. There was cleaner flowing through great, but now no color prints even after 5 cleaning cycles. . . Im now running out of ink! How do I remove the...
This is the only advice I can give you. Try this forum below. It has alot of good information, for the questions you're asking. If you find this helpful, pls rate me. thanks
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Thanks and Good Luck :0)
Mar 03, 2010 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 simply pulls blank paper through when I try to print
I've had the same problem. Drives ya nuts. Found that error said dvd/vcr release something or other on the epson print monitor. In any case, I found that if the front door isn't securely closed. (the front door you open to insert the dvd thingie, the paper will just feed or not feed at all. Once the door is closed on the front, the feed works fine again.
Smles,
Writenright@aol.com
Dec 14, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
352 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
