Question about Asrock 775i65GV Motherboard
Ram problem when i put two 256 ram with 400 mhz speed dual channel dual channel gets activated while working on my system it suddenly gives me blue screen and then i have to restart the system in order to work again, when i use single 256 ram it works fine, i upgraded the bios, changed every setting, i dont know whats the problem
  • toper Dec 19, 2007
    on the first slot i insert ram then it came to unexpected display.. when i turn on again the computer it doent funtion the keyboard, no video... when i inserted in the second slot it opens but after i open windows it shut down then restart then shutdown then no display at all.. what is the problem.. i test the memory on the other computer its ok..
  • 31 Answers
1)not all rams are dual compatible 2)did u try both sticks separately? (1 may be damaged) 3)are they exactly the same? CAS, voltage, etc..? Sometimes different CHIPS cause trouble 4)try changing to 333 mhz if it works, go back to 400 and try either CAS 3.0 (assuming auto is 2.5 or lover) if not working yet, try the "T" seeting to "1". If your BIOS doenst show this setting and is AWARD, after getting into it with DEL, press CTRL+F1 and then look which setting came from the dark... (hidden settings) on Gigabyte boards for ex. it has to be done.
Posted on Jan 26, 2007
SOURCE:
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
How much ram and at what speed will i get best performance all around onn a P4P 800M mobo ? Is running a 2.4G asus processor and has 2 256 sticks running at 44g mhz. I would like to use 1 gig sticks but...
As far as i remember that motherboard has 4 DIMM (ram) slots supporting a maximum of 4GB DDR400/333/266 memory also it has Dual Channel Memory Architecture.
Regards.
Apr 21, 2011 | ASUS P4P800 Motherboard
I need RAM for an Intel E210882 D865GBF motherboard (DIMM, single notch more or less in the middle of the board). What do I need?
It appears your board was manufactured sometime around 2003.
It has supported front side bus speed of 800, 533, and 400 MHz, and has a capacity of up to 4GB Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this desktop board
Hope this helps.
Feb 22, 2011 | Intel Motherboard
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
DDR2 RAM ENQUIRY
Dear Sir
*********** Board is :Foxconn P4M800P7MA-RS2
Max Supported RAM : 2GB DDR2
Supported RAM speed: 533 MHz • 400 MHz • 333 MHz • 266 MHz. I think it deffinately solves your problem.If you have any problem post your comment with more information.
Good luck
thank you for choosing Fixya
MPN P4M800P7MA-RS2
Supported RAM speeds 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 20, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Intel D865 GBF system hangs oftenly
Hello,This always happen when the processor is bad or faulty. when the system is working, check if the processor fan is working too, if the processor is working that means the CPU is faulty.leave the system open and power it on to see if it will hang.
Aug 11, 2009 | Intel D865GBF Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Asrock 775i65GV Motherboard Logo
90 people viewed this question
Top Asrock Computers & Internet Experts
Thomas F. Schneider
Joe Negus
Joe Negus
Davit Mamyan
Davit Mamyan
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
