Question about HP Computers & Internet
Internal cooling fan inside the hard drive is constantly running loudly. This occurs after the system has come out of standby and user is on-line.
  • Frank25 Mar 29, 2009
    I have the same problem. Seems to be when the computer comes out of sleep mode. It is either coincidence OR the DDR (512MB) I installed last week is causing a problem. It is a PNY and I checked for compatibilty with a705w. With the ddr I am currently at 760 MB of RAM (2.93 GHz Celeron Processor). I going to turn sleep or standby mode off and see what happens. Right now as I write this, the fan is on low and running normally. Suggestions?
  • 31 Answers
This is usually caused by two things - overheating on the drive or a faulty thermal sensor depending on which fan is doing all the work - is it a new machine? if still under warranty I would return for servicing. Hard drives do generate a lot of heat - - try improving the airflow to the case also.
cheers Pete
Posted on Nov 30, 2008
Toshiba satellite a100-153 running hot
Something is very wrong here. Does this occur when running on internal battery or only when plugged into the power adapter? At these temperatures the cooling fan should be running at full speed constantly until the temperatures fall to about 50 centigrade or lower. (dependant upon loading and CPU power consumption.) The laptop should automatically power down at the temperatures you are quoting!
Apr 08, 2014 | Amstron Toshiba Satellite A100-153 Laptop...
Laptop fan is lod and error code on startup then quiets down
How To Fix The HP Notebook System Fan 90b Error Message On Startup?
The HP Notebook System Fan 90b Error Message On Startup indicates a serious problem which exists in relation to the heat removal process. Here, as per as HP technical support study is concerned, one of the two possible events is possible: first, the system fan is not at all spinning or even it may be the case that the system fan is not spinning properly and the second cause may be the temperature inside the case which is too high and the fan can't spin fast enough to remove the heat situation.
Steps to fix the HP Notebook fan error 90b
Step1: Working with the exterior vent
·If a user is noticing that the system fan is spinning and is blowing quite warm air from the computer, then cleaning all the exterior vents to remove dust buildup instantly by blowing air through the vent openings is necessary. This should be done while the computer is completely in "off' mode. Dust can further accumulate inside the vent opening and all around internal cooling components to prevent the heat removal process.
Step2: Perform a instant hard reset
·Performing a hard reset can further reset all the recorded thermal values in the memory by enabling you to work with the computer again even if it's only spinning for a short time to access. Save all the important files before it is in service process.
Step3: Updating the BIOS
·While updating the BIOS set-up, it may further help prevent this critical error from occurring in future as suggested by HP Notebook support
Step4: Computer servicing process
    ·Enable the computer service to easily clean up all the internal components and then replace the system fan carefully if necessary. Ensure that all the following items are well addressed while servicing
    ·Thoroughly remove all the available dust from all internal cooling components in the device.
    ·Ensure that wires from the system as well as from the CPU fans are well connected to the motherboard in secured mode.
    ·Ensure that your system fan blades are spinning correctly, and are not producing any unwanted noises. Replacing of the system fan is essential if it's not working correctly. Your above issue is now resolved completely. But do call us if you still have problem with your HP Notebooks at HP notebook Customer Support Toll-Free 1-800-213-8289 section anytime.
Mar 24, 2014 | HP ENVY m4-1115dx 14" Notebook PC -...
Dell Dimension E520 Hard drive constantly buzzing
This could be a sign of a failing hard drive - I would backup all of your important documents immediately to an external drive to prevent you from losing any important data.
As you have already cleaned out the dust , there is a chance that one of the system fans (or the CPU fan) may be faulty or some wires inside your system case might be catching on the fan while it is spinning.
Disconnect all the system fans , so just the CPU fan is left plugged in and then switch on the system and see if the noise has stopped. Then plug each fan back in one at a time to identify if any of them are causing the noise.
Dec 01, 2013 | Dell Dimension E520 PC Desktop
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
Dell Inspiron Fan running constantly and very loud. Can I replace with Quieter Fan? If so, what fan model and Who would you suggest have replace it? Or are there other options? This is driving me...
Stock fans tend to be very loud. If this is a laptop your probably SOL on finding a compatible replacement. If this is a desktop then just buy the same dimensions or just by the fan/heat sink combo's of the same size.
From looking up the fan in question I'd say this is a laptop and there isn't much you can do about it
Sep 20, 2010 | Dell (6F858) Cooling Fan
The cooling fan is really loud and it has an
you can put lubricant oil on the center where you can found the washer holding the motor.
Apr 03, 2010 | Dell OptiPlex GX280 PC Desktop
My vaio vgn-cs320j makes a loud spinning noise that comes and goes every few seconds or minutes. Is it the fan not working properly or some other issue, or is that just what the fan sounds like? if it is...
Usually Sound from Notebook are from CPU cooling fan and from Hard drive.
But It's hardly occur in the case of Hard drive.we called it Hard drive failure and the only solution for this is new replacement.
Your problem could be CPU cooling fan not working properly. Open the Notebook ( it will be easy if you refer to manual on how to open) and start the system now, you will be able to pinpoint what causes the sound.
Clean the CPU cooling fan with an air blower and re-check if the problem still persists.
If OK,then close the Notebook otherwise replace the CPU Cooling fan with a new one.
Jan 13, 2010 | Sony VAIO VGN-CS320J Notebook
Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Dec 13, 2008 | HP Pavilion a1620n (882780664494) PC...
Constantly running
Hello KOKOBEAR,
Is your computer more than a couple years old? If so, then the internal components, like the fans and heatsink may be dusty. When those parts get really thick dusty, the fans are not as efficient, and have to run harder to keep the computer cool.
If you're comfortable opening your case, you can take a look and see if there's a lot of dust. You may want to have an experienced friend or technician do the cleanup, as you may need to take off a part or two to do the really deep cleaning.
Sep 18, 2008 | Compaq (169174-002) - (Refurbished)...
Cooling fan
Yes. It can be replaced. Try to check which fan is making that sound. Do you have a laptop or a PC? On a PC, there are 3 standard fans inside it. one for the CPU, one for the power supply and one for the computer casing fan as well. It depends on which of those fans it's coming from. On a laptop, some laptops' fans actually makes a loud noise which is common but there is a way that it could be lessened but it might slow down your pc and it might overheat it as well. The loud noise on the fans of a laptop actually indicates that it's trying to cool down the system. If it doesn't stop the loud noise, it could indicate a problem switching the fans back to normal and would just continue to spin fast. Try to contact your PC tech for further diagnostics on the laptops fan to indicate if the problem is with the fan or the mainboard as well.
Jan 02, 2008 | Iomega 33089 250 GB Hard Drive
Computers & Internet Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
