Question about Whirlpool SF367 Gas Kitchen Range
When baking the "off" button doesn't shut the flame off
Hey guys, I have a Whirlpool SF367LEKQ Gas Range. For Thanksgiving Day the turkey was larger than the pan so the oil from fat dripped on to the bake burners, igniter and so on, needles to say it caught fire and we put it out with the extinguisher. We saved the turkey though! Since then the bake function will not turn off when i press the "off" button, i tested the broil function and that works fine, it's just the bake that won't shut off, so I'm wondering if it's the solenoid at the gas valve tha's getting stuck, or could it be the bake relay getting stuck not sending a signal to the solenoid. I don't want to buy one or the other part without first knowing if the off signal to the bake relay is different to the on signal, if that makes any sense! What do you guys think could be the problem? Please help! and Thanks a bunch!!!
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Posted on Feb 21, 2009
heatman101
  • 43501 Answers
SOURCE: Gas does not ignite/click on while trying to bake
The problem most likely is with the igniter that lights the burner for your oven. I have just written a tip on that subject. You can view that here.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 18, 2009
SOURCE: Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Posted on Jun 11, 2010
I have a Whirlpool Gas Range with Accu-Bake. On one of my burners the igniter comes on but the burner will not light. You can hear the clicking, but no flame. Is there something that I should clean and...
In addation to the spark do you hear th egas flowing as well? if you do hear the gas and can light it with a match/bbq lighter but it doesn't light with the spark,it could be cleaned by using a safety pin/paper clip and push through the holes where the flame burns all around the burner(s) also steel wool will clean the burner.
Gene
Aug 14, 2011 | Whirlpool Gold GW399LXU Gas Range
My Maytag range Model # MGR5720ADW does not want bake. When calling to bake, the igniter glows, the flame comes on, then shuts off. Then repeats itself. After a short while, I smell gas. The Boiler...
-Sounds like the oven safety valve is not working properly.
-Check it out and replace it.
You possibly can't bake turkey this thinks giving.
Good luck
Mai Lor
Nov 27, 2017 | Maytag Kitchen Ranges
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
E1 F5 Error Code RPD-305-PDS14 Whirlpool Double Oven. Woke up to code. Turn Off/On/Breaker and Appears to re-boot, until you turn the oven on, then 30 seconds later back to E1 F5. I replaced the whole...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Feb 12, 2010 | Whirlpool GBS307PR Electric Single Oven
When using the convection roast, does setting it to 325 show on the display as 300? I am cooking my turkey at 325 and display reads 300.
Your range has the feature called auto recipe conversion,that means it will automatically adjust your settings to compensate for the changes when useing either convection modes, bake or roast,rest assured you turkey will turn out perfect with convection roast. Remember that raosting time will be slightly reduced also with convection roast bakeing. Have a wonderfull Thanksgiving and Holiday season. Good luck !
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
The oven will not stay up to temperature
This range has Direct Spark Ignition System (DSI). If ground is lost or not present on the DSI board (located to right of the display board when looking at the rear), the DSI will not detect the flame. The easiest way to determine if this is what is happening is by listening for the flame to start. If you hear a woosh (flame starting) but still hear the sparking, the DSI system is not detecting the flame. It will re-try three times then lock the system out (there will be no indication on the front panel) and will need to stop the bake cycle and re-start.
To fix, remove the top panel in the back and use an ohmmeter to measure the ground from the DSI board (upper right board) to the ground pin of the power plug. I would recommend placing a starlock washer on all the grounds to prevent this from happening.
For more information see: http://appliancehelp.hypermart.net/DSI_manual.pdf
Dec 17, 2008 | Whirlpool GS460 Gas Kitchen Range
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Whirlpool SF367 Gas Kitchen Range Logo
52 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
