Question about IBM ThinkPad T41 Notebook
IBM thinkpad T41 video problem
Hello, I saw a recent post where you talked about t41's having loose video chips... My screen has randomly been going blank... mostly when being moved... but the test (pressing down on the machine to try to get the chip back in there) hasn't worked... so this is inconclusive. Any other way for me to test whether or not that is the problem I'm having?
Thanks a great deal
    Sergeant:
  • 324 Answers
Yeah, the pushing down thing is a diagnostic that is not totally diffinative, in itself. Another trick is to hold the laptop down and firmly flex the left front corner of the keyboard straight up. If the display comes back, or tries to come back, then you probably have a chip with loose solder connections. Geekman gave you some good advice and you should look into what he suggested, as that is certainly a possibility.
Try those things and get back to me.
Have a superday!
Ron
Posted on Dec 09, 2008
  • IBM Master
  • 32,281 Answers
Connect your laptop to an external monitor, you will need to press the Fn + one of the Function keys that control switching the video to the external video port and the LCD screen.
If the video on the external monitor is perfect then the video chip is OK and the fault is either a faulty LCD or LCD connectors on the motherboard is not making proper electrical contact. You can pull apart the laptop and reseat these connectors, there are usually two connectors.
Posted on Dec 08, 2008
I want to remove bios password from IBM thinkpad t41
It is difficult to remove the Power On and BIOS password because the passwords are stored on an EEPROM chip.
For instructions on how to remove these passwords go to this link.
My Thinkpad - remove Power on Password
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Oct 23, 2012 | IBM ThinkPad T41 Notebook
3 series of 4 beeps on ibm thinkpad t41
The closest diagnostic code that matches what you're saying is the 4 (continuous beeping). This is a video module failure or system board failure. The T41 does not have a separate video module which indicates system board failure.
If you can locate a T41 with a good system board on eBay for less than $50 then you could attempt a repair on the system. Otherwise the system is dead and its cost is greater than its value.
Oct 17, 2011 | IBM ThinkPad T41 Notebook
IBM thinkpad T41 -> get
The IBM Thinkpad has a very strong security system.
If you are seeing a lock symbol when booting then somebody has set the supervisor password. If you can't remember it or guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T41 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 08, 2011 | IBM ThinkPad T41 Notebook
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
I have a T41 thinkpad laptop. Its screen goes
If your computer is still in warranty, you can call IBM support at 1-800-426-7378. If the system is already out of warranty and if you want to purchase the part (motherboard), you may call the IBM Parts Department at 1-800-388-7080 or 1-866-428-4465 (then select option 3).
Jun 07, 2010 | IBM Thinkpad T41 Motherboard - 39T5430
IBM THINKPAD T41 LAPTOP GOES OFF OFTEN WHILES ON
IBM is very sensitive i have the same problem before check your processor fan and RAM. specially RAM causing automatic restart your laptop.
Jun 05, 2009 | IBM ThinkPad T41 Notebook
IBM T41. black screen
It's a common problem with flex of the unit causing the video chip to coming un-soldered from the motherboard. It's possible to repair but very difficult requiring luck and specialist equipment.
http://answers.yahoo.com/question/index?qid=20070710050433AAgGOTJ
Feb 01, 2008 | IBM ThinkPad T41 Notebook
T41 IBM thinkpad monitor goes off
Saw exactly the same think on another t41 i was trying to fix. If it was moved at all screen went off.
Turned out it was corrosion on the motherboard that was causing the problem.
Has it been liquid damaged or got damp in the past?
Jan 07, 2008 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
1,499 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
