Question about KitchenAid Refrigerators
KitchenAid fridge clicks every 5 min or so.
Clicking every 5 min or so... coming from box attach to compressor. Defrost timer?? any comments welcome
  • john_roxboro Dec 08, 2008
    Thanks 20YRSEXP you were ABSOLUTELY right. Got a relay and It's running great. KitchenAid guy said they are noted for weak relays and have an upgraded replacement.
    Thanks again.
    Sergeant:
    Champion:
  • 311 Answers
Compressor relay is bad and needs replacing. Easily obtained as a generic part from any appl part supply. Unplug unit until fixed as it will not work anyway. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
I have a KitchenAid side by side Model # KSRS25CKWH01. iT RUNS BUT DOESN'T COOL OR FREEZE.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem.....
Nov 02, 2010 | KitchenAid Refrigerators
Where can i find the defrost cycle in my freezer? The coils were frozen up so I have defrost everything with a hair dryer. The fan is working but I want to check the defroster.
This timer is generally located in the under the fridge in the front or back. It's generally looks link a small square box about 3 inches square with a single round slotted dial. When you locate the timer using a flat head screwdriver simply turn the dial until you hear the compressor turn off a click. If the fridge is not running you can open the door long enough to warm it up and get the compressor started then turn the switch to make sure you have the defrost timer in the defrost mode. I would also suggest that you check the fridge hourly and make sure that it has started running again after a few hours. If you have a faulty switch this could keep the fridge from starting again. If the switch is faulty and the fridge fails to start by itself then simply rotate the timer until the fridge starts.
Also if your fridge is opened a lot or you live in a high humidity area this too can cause excesive icing.
www.appliance411.com/faq/howdefrostworks.shtml This link will give you a better understanding of fridge operations.
Aug 04, 2010 | KitchenAid KTRP22EK Top Freezer...
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Defrost timer might not be working
twist your defrost timer with a screwdriver clocwise till it will click and compressor shut off, check voltage on defrost heater. You should have 120volts.When wait 20 min if compressor start up back and defrost heater is off ...your timer is fine. It can come on early then 20 min....
P.S. defrost heater located on the bottom of the coil, also make sure your defrost thermostat is frozen when you going to check voltage on your heater. Thermostat located on the top of your coil.
Aug 23, 2009 | Refrigerators
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
How to replace defrost heater ge refrigerator
Replacing the heater is not too big of a job. Unplug the refrigerator, remove the rear panel in the back of your freezer. Sometimes the ice maker and some of the shelf brackets need to be remove to be able to get the rear panel off. Then down below the evaporator you will see the old defrost heater with wires attached on each end. Disconnect the 2 end wires and look at how the old defrost heater was attached. You need to reattach the new heater on this holder or bracket depending on your model number. Put the new heater in and tighten the 2 wires on each end securely. Replace the rear panel and you're good to go. Thanks, Sea Breeze
Aug 21, 2009 | Refrigerators
3 yr old kitchenaid side by side freezer is cold but fridge is only half cold Yhere was some ice buildup in the middle vent so I unplugged for about 5 hours then plugged back in and the next day same...
Sounds like the defrost timer is not working. There is an approx. 1/2 inch white round shaft with a hole in the middle somewhere either inside the refr. section or on the front bottom frame. If you stick a screwdriver in it and turn it clockwise until it clicks, the compressor will shut off and go into defrost. If it doesn't come on after about an hour, then turn it until it starts. Mark it to see if it turns. It should do one rotation either every day or twice a day. If it's not turning you need a new timer. Cheap and easy.
Aug 02, 2009 | KitchenAid (KSRD22FKST) Side by Side...
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge does get cold
Sounds like the motor starter/capacitor may be faulty. How long does the compressor run for? Do you hear a clicking every few minutes from the compressor? If a power surge fried the defrost timer that too could give similar results.
Dec 17, 2006 | KitchenAid Superba KSCS23IN Side by Side...
Refrigerators Logo
74 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
