Question about HP Office Equipment & Supplies
Printer cartridges are sliding side to side very hard in the printer. The printer is grabbing more than one piece of paper at a time and is not printing anything. I own the HP PSC 1410v all-n-one.
  • 37 Answers
Duwhite,
The most common problem with what you are describing is dirt. Almost all ink machines have a encoder strip that goes through the back of the print cartridge. It is a clear mylar strip that has dashes on it kind of like a clear barcode. If this strip or the sensor that reads this strip gets dirty then it will lose its place and slam in the machine. If you can reach this mylar strip you can clean it with a damp lint free cloth. This should help but be careful not to pull the strip out or the machine will not work at all. The feed problem is probably dirt also. There should be a few large rollers that move the paper forward. theses are probably dirty and can be cleaned with a damp cloth as well.
Hope this helps
Posted on Dec 01, 2008
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    Paper get stuck every time I try to print. I notice the paper just slides a bit inside and then on right side it just gets collected and I have to turn printer off to clear paper jam. please help. thanks.
    Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside for any debris.
    3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
    6. If cartridge area is clear, close the cover.
    7. Unplug and re-plug the printer into the power outlet to reset it.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
    Apr 28, 2011 | Lexmark X6170 All-In-One InkJet Printer
    Having a problem with prtinter it's not feeding right keep feeding from right side...tried putting one paperat a time but still not feeding right....PLEASE HELP...
    Using high cotton paper causes cotton dust build up making it hard for the rubber rollers to grab the paper. Check inside for paper dust build up. If so, clean rollers with a window cleaner.
    Another problem is saving too much money on paper. There are some very thin light weight papers which the printer rollers have a hard time gripping. Most printers do well with 22 lb paper. Otherwise you may need to put a piece of scotch tape under the roller so the machine can grab the thinner paper.
    Also check your side paper alignment guide in the tray. As well as making sure your paper is sitting all the way back/down in the tray.
    Apr 13, 2011 | HP PSC 1610 All-In-One InkJet Printer
    Paper unable to feed
    All the Best..
    Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
    How do you fix a paper feed problem in a Cannon iP1600
    1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
    3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
    4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
    5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Good Luck!
    Aug 23, 2010 | Canon PIXMA iP1600 Printer
    When the printer grabs the paper from the tray it grabs it in a corner resulting in a paper jam. It now does it every single time I attempt to print.
    Hello there
    Right this has beed good so far and help lots, so gave it a go.
    This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 06, 2010 | HP Officejet 5610 All-In-One InkJet...
    Paper grabbed from one side
    Hello there
    You may not see a paper jam.
    Feb 22, 2010 | Canon Pixma iP6000D InkJet Photo Printer
    My NX300 is eating my paper every time i try to print. When facing the printer, the right side grabs the paper and starts feeding the right only and of course creates a jam. In other words i can't get it...
    Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    Feb 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    The paper is grabbing from only one side. It is
    Hello this some times works Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    Jan 26, 2010 | Canon BubbleJet i550 InkJet Printer
    I have a m3027 mfp hp printer top feed won't grab
    turn the power off.remove ink cartridge then check there is not any paper jam.aslo check in back side of printer for paper jam .also clean your ink cartridge try other ink cartridge.
    Jan 05, 2009 | HP LaserJet M3027 MFP Printer
    54 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
