Question about Danby DWM5500W Front Load Washer
Panne 004 Dishwasher Danby Silhouette
I have the problem "Panne 004" this morning, when I press the Start button. The model is DDW2405W
Thanks, Nathalie
  • 154 Answers
SOURCE: Error code E 04 was
most error codes are to do with the main board or a switch board and ussually need to be replaced. If you have the manual for it they normally have the error codes and there meaning in them. If not in the manual you should ring your nearest repairer and give them the make model and error cdes and they can ussually tell you what it is from.
Posted on Jul 22, 2008
SOURCE: Danby ddw2406
Simple solution. DO NOT spend the money on a tech coming to the house.
This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
Posted on Mar 24, 2009
  • 1417 Answers
SOURCE: Baumatic WQP12-9213 - Error Code 004?
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Posted on Jun 03, 2010
Testimonial: "Thank you for your help."
  • 4736 Answers
SOURCE: We have 2 Danby air
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
Posted on Jul 18, 2011
  • 20 Answers
SOURCE: Danby silhouette dpac120061 manual
Try to google the manufacturer and model number, sometimes the manufacturer has a downloadable manual online. Otherwise, you may have to contact Danby to order one.
Posted on Jul 15, 2012
How do I fix my Danby Dishwasher? It fills with water then immediately drains.
Most likely the flood switch is triggered. This causes the pump to operate as soon as you start it. Check if the float at the base comes up when you press it by hand. If not the float spring might be stuck and pressing the flood switch underneath.
Sep 01, 2014 | Danby DDW1809W Builtin Dishwasher
Press the "power" button and then set the humidity level to about 50%
May 11, 2014 | Danby DDR600R Silhouette Dehumidifier
Door latch
Oct 20, 2013 | Danby DDW2406 Stainless Steel Built-in...
Jul 15, 2012 | Danby Heating & Cooling
I would like to get a manual for a Danby dpa 10030 conditioner. Can you help?
Since your model has been discontinued the Owners Manual is only available through Danby's Consumer Help line 1-800-263-2629. They can email it to you as an attachment.
I hop this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DPAC10031 Silhouette 9,000 BTU...
Need instruction manual for Danby Silhouette dehumidifier DDR583R for explanation of icons
Well can't seem to find your particular model but they have what looks like yours
Jul 17, 2011 | Danby DDR600R Silhouette Dehumidifier
I have a Danby Silhouette 10,000 BTU portable A/C.. it has recently stopped turning on. The panel with buttons lights up and works, but the unit itself will not turn on. Any ideas on what the problem is?...
If the unit was set in Automatic Timer Mode, it will not turn ON until the set time is reached. Try deactivating the Timer Mode. If that doesn't work. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. During this timeout, the unit should have time to reset itself, so that when you plug it back in and turn it ON, it will have reverted back to the original factory settings.
If you have misplaced your Owner's Manual, I have included a link to a Danby Model that is similar to yours, in the way that it functions. You can download and print the manual for future reference if you like.
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Danby DPAC10031 Silhouette 9,000 BTU...
Need a copy of the manual
Here's a link to the Owner's Manual for your Model Danby Portable Air Conditioner.
Your model has been discontinued, so download and print this manual for future reference. Making sure to keep it in a save, accessible place.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Danby DPAC12031 Silhouette 12,000 BTU...
I need the settings to run the unit so it takes the water out of the air. The unit was a floor model without papers.
hello. Here is the link to Danby Customer Service. Call them and tell them what you need.
ps. please rate this answer as very helpful. thanks
Mar 24, 2010 | Danby DDR600R Silhouette Dehumidifier
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Danby DWM5500W Front Load Washer Logo
193 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
