Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Samsung HLP6163wx/xaa blue on screen
I don't know how to exactly explain it but there is blue on the screen that sometimes comes up in the outlines of things on screen, but other time with take over the whole screen and it will flicker from the blue to normal color and back. Here is a video of it hope you can see.
http://www.youtube.com/v/GdLbEyECbaA&hl=en&fs=1\"> name=\"allowFullScreen\" value=\"true\">http://www.youtube.com/v/GdLbEyECbaA&hl=en&fs=1\" type=\"application/x-shockwave-flash\" allowscriptaccess=\"always\" allowfullscreen=\"true\" width=\"425\" height=\"344\">
if you can" t here is a link
http://www.youtube.com/watch?v=GdLbEyECbaA
  • 59 Answers
SOURCE: Samsung HLP6163wx
when is the last time you changed the lamp ?  are the fans clean
Posted on Oct 23, 2007
Mr_Wizardtex
  • 205 Answers
SOURCE: no picture, humming
lost the lamp, replace lamp
Posted on Jul 07, 2009
techman007
  • 1112 Answers
SOURCE: Samsung HLP6163WX/XAA DLP HDTV - lamp and noise issues
Hello:
Replace the color wheel again, its gone bad again. the clicking is the ballast trying to fire the lamp. The Ballast will not fire the lamp until the color wheel has reported it has reached an RPM of around 9000rpm. This is a normal sound. Most of the time the color wheel will make a loud whining sound when bearings go bad, sounds like a Airplane using reverse thrusters when landing and a even louder sound when it shatters in the housing. Also the reason it may of gone bad so soon is because they make to versions of this color wheel, Bearing type and the Air type. I don't know who installed your color wheel, but it should of came with a small tag or paper of some sort with numbers on it. Most people throw this away when it is very important to let the unit know which type of wheel is being installed to set the parameters for either type of wheel. Most people who install colors wheels themselves to save money do not know this, and the only way to install the new settings is thru the Factory Service Mode. There are also color parameters to input for the type of wheel being used.
This is your basic Color wheel 101..
Hope I gave you some insite of what may of caused your problem...Please leave comment if more info is needed..Lavell
Or email me: Delhielectronics@live.com
Posted on Oct 01, 2009
  • 69 Answers
SOURCE: I have been trying to fix my hlp6163wx/xaa I
could be the colorwheel. listen right after the power button is press you should hear a slight wind up noise coming from the rear of the tv. if you dont hear that the colorwheel may be bad
Posted on Feb 07, 2010
Testimonial: "It is the color wheel we took it apart and the color wheel is broken inside, thank you so much for your comments!"
Mas Baz
  • 177 Answers
SOURCE: i have the samsung fpt5084 plasma tv, and it has
hello,
I've watch your problem on youtube , that problem can be from main board. But to make sure main board problem, you should check without inputs first. Unplug all input (HDMI, Component, AV in, PC).
Than turn on your tv again. If that conditions still appear, i suggest you to call samsung technician to repair it.
Good luck.
Posted on Apr 07, 2011
NO OTA channels
Not sure this set has a built-in digital tuner. if not, you will need a digital tv converter.
Apr 08, 2014 | Samsung HLP6163WX/XAA
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a samsung hlp6163wx/xaa I replaced ballast and bulb. Color wheel sounds good but just a dark blue picture and perfect sound what could it be?
Some things to be aware of here--if the color wheel turns too slow set will shut down---if you hear a fan like or high pitched sound it is the wheel.
If a uniform blue and dark it is likely the DMD which is the box the wheel connects into and can be purchased by itself (forget that as for about 50 more than it costs you can buy the entire light engine that comes with it)
Bottom line: Likely a bad or damaged optical light engine.
A photo posted here or somewhere else with a URL location might tell me more.
further questions? Press the make a comment button on this page.
Mar 25, 2012 | Samsung HLP6163W 61" Rear Projection...
Microwave keypad does not respond and screen reads SE
"SE" error means you have a shorted membrane keypad.
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Aug 20, 2010 | Samsung SMH9151 Microwave Oven
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
Hello:
Oct 01, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
