Question about Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000 Internal Battery Replacement
I purchased a new internal battery (CR  2016), and when I removed the old one to replace it, I forgot to note which side was facing up.  Should the flat face, with the name engraved on it be facing up or down?
  • sportsguru Jan 25, 2009
    i cant even find the place to put the internal batery?? help please? we hadnt used this camera in ages and had left bateries in it went to use it and found the bateries had coroded, not real bad, but now when we put the bateries it it flashes 99" and the baterie compartment gets realy hot??
    any sugestions
  • 41 Answers
The flat face with the name engraved on it should be facing up and out towards you.
Hope your up and taking photos soon! :)
Olivia~*
Posted on Dec 01, 2008
Loaded film camera will not work asks for program how do i do this How do I set the program on my Minolta Maxxum 7000
it might be the internal battery. remove the battery holder and remove the screws on the metal plate. gently lift the plate and replace the battery. remember the different length of the screws.
Oct 29, 2009 | Minolta Maxxum 7000 35mm SLR Camera
How do i replace internal battery
remove batt. holder, then remove screws on metal plate. carefully lift metal plate then replace batt. remember different length of screws. it may take a while for systems to turn on.
Aug 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Where can i buy a battery holder for a minolta maxxum 7000.
try a camera repair shop for a good used one, no new parts are available. or try ebay. you may have to buy a complete 7000, then keep it for parts.
Jun 22, 2009 | Minolta Maxxum 7000 35mm SLR Camera
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Insertion of battery +face up or down
Insert the cr-2016 face up. The side with the battery number and printing goes.
Nov 10, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Sep 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta 7000 internal battery
I would recommend haveing it checked by a camera repair company or a local tech if you know one.
Il look into this though will get back to you.
Jul 22, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000 camera lithium battery
The lithium button cell is under the metal plate where the battery holder attaches. There are six screws holding the plate to the camera. I believe the cell is a CR-2025.
That being said, replacing the lithium battery will only restore the cameras ability to remember your settings and frame counter when the regular batteries are not on the camera. It will not restore functions of the camera.
If the camera is not functioning properly, you have a power problem with the main batteries, not the memory backup cell
Mar 21, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta 7000 slide on/off button missing
CR-2016 lithium batterys for a 7000 can you get the batterys on there own or are they in a holder of two?? as i can not seem to get mine out of the holder
Nov 26, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 35 mm camera
I had the same problem. After I replaced the lithium backup battery, everything works perfectly. It is a CR2016 watch battery and it is located behind the silover plate inside the battery compartment. Remove the 6 screws and replace the battery. Note the polarity when you remove the plate because the camera will not operate if if it is put in backwards.
H
Nov 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
209 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
