Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Ryobi 40 cc bar oiler not working
Not getting oil to the bar. the end of the hole is not pluged
  • lenz1 Mar 26, 2009
    Were can I find the worm gear to buy? My saw would not oil teh gear and when I checked teh gear was badly worn. I still have to fine tune it. Please can I get further details on the servicing?
  • 211 Answers
Hi customweldi
check the oil filter,the oil line ,the oiler and the worm gear.Clean the bar and the oil hose.
the best savumihai71
Posted on Dec 01, 2008
Why wont the auto chin oiler work
why is your chin squeaking??
Sep 08, 2017 | Garden
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Homelite Problems
make sure the holes on the bar are clean if they are fill with so-dust the oil will not pass inside of the bar
Oct 26, 2013 | Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Oiler not working
Remove the bar/chain and clean the oil port on the side of the engine near the sprocket. Start the engine and look for oil oozing out of the port with the engine running fairly fast. If nothing, check the oil lines, tank filter, and then the oil pump. If ok, then clean the oil passages in the drive end of the bar and particularly the small passages from the large holes to the chain groove. Clean the entire groove and check the sprocket (if equipped) at the far end. Reassemble the bar and chain, then adjust the bar so that the chain doesn't droop from the lower edge (the teeth cut toward you on the bottom) and the chain moves easily by hand. Hope this helps!
Mar 27, 2010 | Garden
Auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | Homelite Garden
I have a homelite xl, UT# 10655- the chain oil seems to be leaking and coming out of the exhaust and continues to leak after shutting off the chainsaw. Any ideas on the possible cause?
Your saw is listed as an "XL Chain Saw UT-10655" here:
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please take extensive notes & some digital pictures will help during reassembly.
Lou
Feb 27, 2010 | Homelite Garden
Blade will run for about a minute. Then locks up if i give it a minute and force the chain to move it will run for a minute the i will have to wait again
Need to make sure your oiler is working. If not the chain will get hot and expand thus locking it up from friction. There is about a 1/4" hole in the rear of the bar where the oiler feeds oil to the chain. Sometimes this hole gets filled with sawdust. Clean it out and make sure you're getting oil to the chain. When you rev the engine and the chain turns you should see it throwing a small amount of oil off the tip of the bar towards the ground. If you don't see the oil then you need to get that fixed.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Hi and welcome to FixYa,
Areas/components to check/clean and ensure no clogging:
  • oil filter
  • oil line
  • oiler pump
  • worm gear drive
  • bar
  • oil hose/feeder to the bar.
For the exploded parts diagram of a PCN4040, pls click here.
Good luck and thank you for using FixYa.
Feb 16, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
338 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
