Question about NetGear WGT624 Wireless Router
Connection issue I have a wgt624 wireless router, it says that all is connected and it is but intermittently it gets a signal then looses it then gets it back again, also it is saying to validate settings? Regards Kristin
  • 1 more comment
  • ardisga Dec 05, 2008
    same issue here ... using Netgear WGT624 wireless Router with Comcast Cable modem service...bypassing the router no connection issue when i connect the router the connection drops every 15 seconds, reconnections and drops again and keeps telling me its verifing the connection or cannot locate any wireless connections and i am sitting less than 10 feet away
    this just started about a week ago prior to that no connection issues..HELP!
  • Sean Coldiron
    Sean Coldiron Dec 08, 2008
    Mine does kinda the same. I'll be surfing or downloading something and data transfer will stop, and I'll start getting those "server took too long to respond" messages from my browser. All lights will be green and look as though everything is normal, wireless adapter on the laptop also says full signal and excellent connection. When I try to repair the connection through the wireless adapter, it won't reconnect and I'll have to go power cycle the router and reconnect to my wireless network. It'll work for a few more minutes after the power cycle then do the same thing all over again. Time for a new router?
  • stevep01_98 Dec 26, 2008
    Using my WGT624 wireless or hard wired with a motorola surfboard modem I have to constantly reset the router to maintain an internet connection.HArdware v3 firmware v.2.11_1.0.1
    Problem Solver:
  • 6 Answers
This could be a number of things but here is a few good things for starters.
1. Turn off encryption if using WEB or other security features like MAC address Filter. Try it and see if that is the issue, if not go to next step.
2. Backup your Router Config, Factory reset it and or upgrade to the latest firmware.
3. If on Cable Modem have them Flush the MAC Address and IP's from the Modem and see if you can obtain a new Public IP to the WAN port on the router.
Let me know if none of the above works.
Kind Regards,
Posted on Jan 03, 2009
Hi, i have bought this netgear 108mbps wireless router WGT624, 2 weeeks ago, it was working good, but now suddenly it shows less mbps and when tried to restart it, now it not working, i mean it says in my...
I suggest try to check the netgear if it is connected to the internet. If the wirelss signal is good, it might be the internet connection is having some issue.
What you can try to do first is:
1.connect a computer to the netgear directly using an ethernet cable (RJ45)
2. click start then select run type cmd (It's a black screen)
3. type ipconfig/all then press enter on your keyboard
4. check the ip address it should be 192.168.X.X and the default gateway is 192.168.0.1 or 192.168.1.1 depending on the router default ip address
5. on the black screen type ping yahoo.com then enter on the key board
*if there is a "reply from" message it means there is an internet connection going in the router and you need to configure the router. *If the message is "unable to detect" or "request timed out". You need to contact you Internet Service Provider for assistance.
Nov 21, 2009 | NetGear WGT624 Wireless Router
Start up and Signal problems. need to download WGT624 set up
.chk files are normally those produced by the system after a hard drive repair or some such, and shows lost clusters on your drive.
Your Broadband modem feeds the router (your problem device), which in turn connects to the computer's Network Card, the one with the RJ45 connector. The smaller connector goes to your modem, for use with Dial-up signals, not broadband. Cable modem feeds router, router routs signals to various computers, via RJ45 cables. Your router is probably for 802.11g signals, used by the majority of networked computers. The 311 in your computer plugs in to the 624 router. They work together to get you on the Internet.
Nov 07, 2009 | NetGear WGT624 Wireless Router
Why does my WGT624 keep loosing connection. I would be on the Internet and for some reason, I would loose connection to the Internet. I have a Dell Inspiron...1521 computer.
In my case too this happened initially with my lenovo y410 laptop with netgeat router. In laptops if th ewireless network is set with "public" profile then the connection is sometimes dropped by the driver. If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then you can change the wireless settings of your laptop to be in "private" network, which will solve your problem.
Oct 31, 2009 | NetGear WGT624 Wireless Router
What steps do I take to allow my 2nd computer, a laptop, wireless connection to internet through my WGT624 wireless router?
>Switch on your laptop wireless..
>Goto Network sharing center from network connection settings menu from control panel..
>Search for New Connection and select your Wifi router And mark it as shared..
Aug 14, 2009 | NetGear WGT624 Wireless Router
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Wireless internet connection
Fog will not affect radio signals. Please go to the following website and follow the instructions.
http://kbserver.netgear.com/kb_web_files/n101676.asp
Oct 30, 2008 | NetGear WGT624 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
Plz solve
need more information - do you have cable? DSL? Are you able to connect when you put the Ethernet cable directly into your computer and bypass the wireless router? The wireless signal is only indicating that your router is "broadcasting," but does not mean you have a usable Internet connection.
Feb 17, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Wireless network
Have you looked at these posted solutions? http://www.fixya.com/support/t133938-wireless_connection
Feb 14, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
