Question about LG W2252TQ Monitor
Digital Power Saving Mode
Whenever I turn on my computer it will load up everything, but as its abhout to go to my desktop the screen will flash black then navy blue and say "Digital Power Saving Mode" In a little blue and white box. Then the screen goes black and you cant do anything with it. The power button on the monitor which is usually blue or no color at all turns a yellow-orange and leaves me very frustrated.
  • Sandrutee Dec 26, 2008
    I have the same problem , tho I can do a bit more than that ,but I wish to expand that time
  • Anonymous Jan 01, 2009
    I've got the same problem. I bought this LCD monitor last week and it has occurred several times. Need urgent help. :-(
    Scholar:
  • 70 Answers
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Posted on May 28, 2009
Acer Aspire E360 is staying in power saving mode
Click on "Start" in the lower left-hand corner of the desktop. From within this menu, select "Control Panel." Double-click on "Power Options" located inside the Control Panel. Turn off the power saver plan by selecting one of the other power plans listed inside the Power Options dialog box. If there are no other power plans available, you can create one. Create an alternate power plan by clicking on the "Create a power plan" link on the left-hand side of the Power Options dialog box. This will open another window allowing you to create a power plan of your own. Select the type of power plan that you want, and enter a customized name for this plan. Once you have done this, click "Next." You will then be able to edit the plan's advanced settings to include how it handles the display, sleep mode and brightness settings under the battery and when it is plugged in. Hope this helps.
Jan 20, 2013 | Acer Aspire E360 PC Desktop
My PC desktop is in power saving mode, how can i put into normal mode?
This is what i do whenever someone asks me to remove their PC from power saving mode.
Follow there
Try clearing the NVRAM as follows:
-Turn off the computer
-Disconnect the monitor.
-Unplug the computer.
-Take out the video card.
-Remove the CMOS battery for a couple of minutes.
-Insert the battery.
-Connect the video card and monitor.
-Turn on computer.
Apr 05, 2011 | E-Machines eMachines Desktop PC
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Analog Power Saving Mode Problem!
Have you checked you power saving options in Control panel.
If this is a desktop, unless you are a energy miser, I would change your power saving options to never on all options, turn off hibernation and suspension for when you are playing games.
You can find this in control panel under power Options.
Let me know if this helps.
Thank you
May 18, 2009 | LG 22" FLATRON LCD Monitor
Monitor not starting up -
I think the Power Settings in your Computer needs to be changed. As whenever your computer been IDLE, it goes in a Power Saving Mode.
Adjust your Power Settings from the Control Panel "Power Options" and set them to "Balanced Power Settings" or as per your requirement. There are lot of options their to mention.
Hope your problem will be solved.
Apr 23, 2009 | Computers & Internet
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
WARNING: PC ENTERING POWER SAVING MODE
sounds like a faulty power supply unit
Mar 24, 2008 | HP Pavilion a450n PC Desktop
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Black Screen
DISPLAY HAS POBABLY WENT BAD.
BUT THE WAY TO MAKE SURE IS TO CONNECT YOUR COMPUTER TO A DIFFERENT MONITOR TO SEE IF YOU GET THE SAME RESULT
Jan 16, 2008 | Sony VAIO VGC-V617G PC Desktop
LG W2252TQ Monitor Logo
495 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
