Question about Dell Dimension 4500 PC Desktop
Amber light on power button of Dell Dimension 4500
Hello. Tried to turn on my computer and the power button turns a solid amber color. Opened the computer up and there is a solid green light on the motherboard. Its not making any sounds. Please help.
  • killa4keepz1 Dec 19, 2008
    i had this amber light problem too. i called dell and the technician said to refeed the ram and try to turn it on, which didnt work. since that didnt work he said that it would be the motherboard. i took the tower to a friend who knows a lil more than me, and he ordered another motherboard that was compatible of coarse. when he got the motherboard, he installed it and when he tried to boot up it would run halfway and stop. so far he cant complete the boot up. hes tried to test different parts to working computers. but cant get a solution to the problem. it may be the processor but hes afraid to test it and fry it. the motherboard has proprietary connections so you just cant take the motherboard and connect it to other pieces and throw it into another case. he tried to put it into another dell 4500s case and still no luck.......what could this be???? so far it looks as if it would be better to buy another working tower for 250 bucks and it be an upgrade compared to the 4500s. any info would be nice
  • 31 Answers
Ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Posted on Nov 30, 2008
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Blinking amber light on the on/off button.
No light : The computer is turned off (S4, S5, or mechanical OFF)
Steady green :The computer is in a normal operating state
Blinking green : The computer is in a power-saving state (S1 or S3)
Blinking or solid amber See "Power Problems"
check power
Sep 06, 2011 | Dell Dimension 4300 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Pc has a solid amber light when i try to turn it on now so i unplugged it. I moved the comp around and turned it on again and it had a solid green light but nothing was on. the third time it went back to...
Hi Thanks for your question
I think you are right about power supply. This would be my diagnose. Be careful with your PC because faulty power supplies may fry your motherboard. I would recommend replacing it. This isn't expensive and it's pretty easy to get done. I hope this helps. Good Luck
May 19, 2010 | Dell Dimension 4400 PC Desktop
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
Amber light on start button of Dell Dimension 4500
This is one of three things.
1. Bad Power Supply - Check to see if the fan is spinning
2. Short in the the wiring or Bad piece of Hardware - Check wiring make sure none of it is damaged. Disconnect one component at a time and try powering the PC on.
3.Badmother
Try steps 1 and 2 and if those do not work it is a bad motherboard.
This from a Dell certified Technician.
Oct 16, 2009 | Dell Computers & Internet
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Blinking Amber light on the tower
If it is one the front near the power button, it indicates power supply is failing...and other indicator is the motherboard is failing.
Now if it is in the rear where the ethernet cable hooks up...solid amber means you are connected, blinking amber means activity on the line...no problem there- very normal. I hope it is in the rear.
Please leave rating, thank you
May 07, 2009 | Dell Dimension 4500 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4500 PC Desktop Logo
1,758 people viewed this question
Alun Cox
