Question about HP LaserJet 1200 Printer
3" wide swath no toner laid down
After cleaning thoroughly, performing the clean test 3 times and shaking the toner cartridge, the pint output still has a blank spot from 2" - 5" across all the way down the sheet. There are also 3 little toner marks on the right hand side column, that look like the letter l at the 2", 5", and 8" vertical points.
  • Mitch Patterson
    Mitch Patterson May 11, 2010
    You probaly need a new Toner Cartridge, and possibly a new imaging cartridge(if its not built into the toner), also called a OPC Drum, or imaging unit
  • 628 Answers
Try replacing the toner cartridge. They will exhibit those symptoms when the toner is low.
Posted on Dec 01, 2008
How to replace toner cartridge
-Open the front cover
-pull the old toner cartridge out.
-Remove the new toner cartridge from its bag
-Thoroughly shake the cartridge 5 or 6 times to distribute the toner evenly inside the cartridge.
-Thoroughly shake the cartridge to assure maximum copies per cartridge.
-Remove the paper protecting the toner cartridge by pulling the packing tape.
-Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
-Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
-close the front cover.Make sure that the cover is securely closed.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 13, 2012 | Samsung SCX-6320F All-In-One Laser Printer
Hp laserjet printer one side too light printing.....just like a wide line up to down.....
Check if the toner is low.
1. Pull the toner cartridge out and move it gently (up/down - left/right)
to spread the toner in the cartridge.
2. Execute the Cleaning procedure (Menu).
3. If the problem persists, exchange the toner cartridge.
Aug 16, 2011 | HP LaserJet 1320 Printer
Does fault cartridges cause double images when printing using laserjet P3005 Printer?
Try pull-out first the toner cartridge and then shake it, in 5 to 10 second. then insert again and test print. if same problem? clean the exterior using soft and clean cloth to wide dust, paper stain off of the device.this built up cause print quality problems, such as toner cartridge. power on your printer,
1. Press menu
2. Press down(in the laserjet unit) to highlight configuration device, and then press check (select).
3. Press down to highlight Print Quality, and then press check (select).
4. Press down to highlight Create cleaning page , and then press (select).
5. Remove all paper from try1.
6. Remove the cleaning page and load it face-down in tray1.
7. At the device control panel, press down to highlight Process cleaning page, and then press check (select).
Hope can help you,
Regards
Jul 19, 2011 | HP Office Equipment & Supplies
We have an HP Colour Laserjet CM1312nfp which has started to print with a wide faded area down the centre of the page. We have tried putting it through the cleaning process but this hasn't fixed it. Any...
Most of the time this is a simple fix. Just remove the toner cartridge and while keeping it somewhat level, shake it back and forth. This will re-distribute the toner inside the cartridge. Then re-install the toner and test. This also usually indicates that the toner cartridge is starting to get low on toner so have a spare handy.
Thank You for using Fixya.
Jan 10, 2011 | HP Office Equipment & Supplies
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
Oct 29, 2010 | Brother MFC-9440CN Laser Printer
Installed new cartidge - white down the center of the sheet - print on each side of paper, about an inch wide
Make sure you pulled the seal tape out of the cartridge when you installed it. Remove the toner cartridge and while holding it relatively level shake it from side to side. Re-install the cartridge and test. If it makes a good copy now you are all set. If not then I would return the cartridge and get a replacement under warranty.
I see this all the time with new cartridges. Most of the time it is caused by the toner in the chamber being packed to one side or the other and shaking it from side to side wil even out the toner.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | Canon PC-940 Black and White Copier
Color does not distribute evenly across the page
Open the printer and remove all toner cartridges. Thoroughly clean the inside of the printer. Wipe down the transfer belt. Make sure all contacts on the toner cartridges are clean.
Are you using recycled toner cartridges? Try OEM toners.
Jan 08, 2010 | HP Color LaserJet 2600n Printer
I just replaced the toners kits but the red and yelow ones are still on red. If I try to print it says thjat yelow and magenta toner kits are nvalid
Replace the color toner cartridge with a
new one
1.Take out the toner cartridge and thoroughly shake. In doing so, you can clean the inside of the Imaging Unit
Jun 11, 2009 | Xerox Phaser 6110 Laser Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617 the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
HP LaserJet 1200 Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
