Question about HP 12c Calculator
Wrong format for numbers displayed in HP 12C
Somehow the display of numbers in my HP12C has been changed to show numbers like the following
200,00
how do I get it back to the standard format that would show
200.00 only - i.e. there is a comma where there should be a decimal point
thanks
Turn calculator off, while holding down the decimal point, turn calculator back on, should change comma to point
Posted on Jul 01, 2013
  • HP Master
  • 2,794 Answers
It's been awhile since I used one of these but there should be a decimal function on the keys. Make sure you put a 2 in there before pressing it and it should display the format using 200.00
Posted on Nov 30, 2008
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
What does D.MY mean on my HP12c display screen
It means the date format is set to Date-Month-Year. To switch to Month-Date-Year, press g [M.DY].
M.DY is on the 5 key.
Feb 11, 2014 | HP 12c Calculator
Letters d.m.y. on display in my HP12C. How do I remove?
To switch from Date-Month-Year to Month-Date-Year, press g [M.DY]
M.DY is the g-shifted function of the 5 key.
Jan 26, 2013 | HP 12c Calculator
HP12c seems to not have enough room for numbers BEFORE the decimal point. I try to enter the number "85" and all that will show up is the 8.000000000
Initial Setup
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
You need to hold the "F" key.---------
    1. Press and release the gold PREFIX key (f).
    2. Press the number key for the desired number of decimal places (0 through 9).
------------ Click this link below and follow the procedure:--- http://howtobyme.blogspot.com/2011/07/hp-12c-calculator-help.html
----------- This should help.Thanks.Helpmech.
Jul 21, 2011 | HP 12c Calculator
My hp12c displays D.My, how do I remove this?
You're in Day-Month-Year format. To switch to Month-Day-Year format, press g MDY.
Oct 15, 2010 | HP 12c Calculator
HP12c showed expected display for low battery (star in lower left), put new batteries in and could not get any display at all. Took betteries out of mine (working great!) and now the one not working shows...
Resetting the calculator using the keyboardThe easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
Aug 04, 2010 | HP 12c Calculator
My decimal changed to a comma, how do i change it back?
P12c display from Comma to Point This document describes how to change the display of the decimal point on the HP 12C (HP12C) Calculator from a comma (commas) back to a decimal point.
Instructions
  1. Turn off the calculator.
  2. Hold down the decimal point.
  3. Continue to hold the decimal point key, while turning on the calculator.
The comma should change back to a decimal point.
Explanation The comma is the European equivalent of the decimal point.
This procedure is also applicable to HP12CP (Hewlett-Packard 12c Platinum) and HP12CPA (Hewlett-Packard 12c Platinum 25th Anniversary Edition).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 04, 2010 | HP 12c Calculator
HP 12C went into scientific notation and will not come out of it
To exit the scientific display format press the [f] key followed by the number of decimal digits you want.
Hope it helps.
Oct 31, 2009 | HP 12c Calculator
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
12C Calculator
Press "f" then 2. The number you press after "f" sets the number of digits to the right of the decimel point.
Feb 24, 2009 | HP 12c Calculator
HP 12c Calculator Logo
228 people viewed this question
Ben Johnson
