Dim display on reciever. Sony STRK670P
The display after about 6 months has gotten almost unreadable. It keeps getting dimmer and dimmer. Its so dim that you have to be right on top of it before you can see it. I was wondering if any one out there has had the same problem and if so was it hard to fix? I repair electrical components where I work so I'm good at fine soldering. My only concern is weather or not it is fixable before I pull it apart?
Thanks in advance,
Dave H.
circuitcity
  • 137 Answers
SOURCE: Sony PFM-50C1 Fuzzy Dim Display
Just want to let you know that the problem you are having is a bad X board. This board may not be available from Sony, because it is sold as part of the panel
Best regards
CircuitCity
Posted on Dec 06, 2007
  • 4234 Answers
SOURCE: sony home reciever
If the problem was blown "output transistors" expect a cost of about $6-$8 per transistor (there are 4 total in the receiver) plus a few bucks for an emitter resistor and perhaps $2 each for the driver transistors (4 max per receiver). Also add in the local labor rate.
Please note that these are estimates and that additional parts may be required depending upon how smoked the output section actually is.
Dan
Posted on Mar 25, 2008
  • 8 Answers
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Posted on Feb 06, 2009
  • 114 Answers
SOURCE: Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Posted on Mar 21, 2009
  • 3 Answers
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
Display is dim on my sony hi-md recorder mz-m100, how can i fix that?
1) Make sure the battery is all charged up.
2) Live with it. Seriously. It will cost you $100+ to replace the display.
Nov 15, 2014 | Sony Mz-m100 Hi Md Minidisc...
I changed the light bulbs in the fixture it controls, now it does not work. What is wrong?
This switch is designed to dim incandescent lamps. It has nothing in its description about being used with CFL (compact fluorescent lamps) types. If you are attempting to dim standard CFL types, it will not work.
CFL's are available in both dim-able and standard types. As you may have guessed, only those marked as "dim-able" will work with a dimmer switch. Dim-able CFLs cost slightly more than standard CFLs but may be controlled by any switch. Dimmer switches may only control incandescent and other type lamps that specifically state they are compatible with dimmer switches.
If you are attempting to dim incandescent lamps, make sure that you are not trying to dim lamps with a total wattage greater than the dimmer can handle. Most dimmer switches are rated for 600 watts, if you have two dimmer switches under one wall plate, the wattage rating drops to about 500 watts. This de-rating is because of the heat the switches create. There are dimmer switches that can dim more than 600 watts, but the price skyrockets for a 1000 watt dimmer, and keeps climbing.
If your wattage is within the limits of the dimmer, check the bulbs. If they are ok, the dimmer may have failed and require replacement.
If you found my reply helpful, please rate it "4 thumbs up". Good luck & thanks!
Aug 16, 2011 | GE 18027 Dimmer Toggle OnOff with Slide...
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
The unit display is too dim.
Bad news so please don't rate me on this. The display itself needs to be replaced and the part is nla (no longer available)
Nov 09, 2009 | RCA RT2500 System
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Turn lights on and radio and clock dim.( 96 cougar xr7 3.8 )
they should dim unless they are unreadable check the dimmer control at the headlight switch
Jul 06, 2009 | 1996 Mercury Cougar XR7
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Dim Display
On newer stereos, you might have to experiment with the "panel" wire.
I just installed a VR3, and discovered that the more voltage on the "panel" wire, the dimmer the display.
With no connection, you get full (daytime) brightness. With full voltage, you blank the display.
I wired mine up to the car's instrument lights through a 10Kohm trim resistor so I could adjust the "night" intensity. But if I dim the car's instrument lights, the stereo gets brighter. Oops.
Older car -- I can't just flip a software bit. ;)
But I gather a lot of new stereos are like this. The display on my (factory) stereo in the Mitsu dims a fixed amount when the lights come on, but doesn't adjust with the car's instrument dimmer.
Sep 23, 2007 | Car Audio & Video
66 people viewed this question
 Grubhead
Grubhead
