Question about LG WM-2277HW Front Load Washer
I have a new LG steam Washer model # WM2688H*MA. I have had it for about 3 weeks, i go to turn it on to wash clothes and the computer display is lit, but blank. Please tell me what i need to do. I have unplugged and replugged and it did not work.
    Sergeant:
    Champion:
  • 311 Answers
Need to call LG for svc; unit is in wty. Nothing you can do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
Need to change stator and rotor assembly in WM2688H*MA
The stator is stationary mounted to the outer tub the rotor attaches to the spindle of the basket which is a shaft that goes thru a bearing to get a definitive answer remove the back panel remove the rotor turn the center bolt till it loosens keep going as this will back the rotor off the stator you will have to pull with a little effort strong magnets to get it off now try to spin the basket by hand if stiff you have a bad tub bearing.
Apr 02, 2014 | LG Washing Machines
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Computer display is blank
Suggest you contact store where you purchased item from, or contact repair agent, if you start messing with it , you will invalidate your guarantee.
Nov 30, 2008 | LG WM-2277HW Front Load Washer
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Can't make tub clean setting work
Thanks to a couple of previous responders, 6 months of frustration has now ended - I can now run the Tub Clean on my LG Steam Washer! I first want to say that it is important not to get excited and start pushing buttons randomly, as I think I had been doing for all these months when I couldn't get Tub Clean to work by pushing the button in for 3 seconds. Just do the following, which combines and expands on a couple of previous responses:
1. I had to deactivate the Spin Sense, and if your Spin Sense is ON, you will have to do this too. (It is ON if the spin speed light flashes while any of the wash cycles is in progress. If spin speed button does not flash while a wash cycle is in progress, the Spin Sense is already off.) So how to deactivate Spin Sense? Select Speed Wash, and start the cycle. Let it run for about 20 seconds and THEN push and HOLD IN in the Spin Sense option button for 3 seconds. The blinking spin speed button will stop blinking and you will then know that the Spin Sense is OFF.
2. Once Spin Sense is off: Start with your machine turned off. Then push the power button on and select the RINSE AND SPIN option button. Then START the Rinse and Spin cycle. Let it run for about 5 seconds and then PUSH IN AND HOLD THE TUB CLEAN OPTION BUTTON FOR 3 SECONDS. You will then see the little LED light panel show something that looks like tcl. And you are there! Just leave it alone .... the LED will change to one hour and 25 minutes. And it will clean your machine just great.
3. Don't forget to put your bleach in the detergent cup before you start all of this.
I want to thank the two responders above who gave me the essential features for this fix. I forgot to make a note of their names before I started this response, but you can see who they are. I am so excited. Now EVERYTHING works on my LG Steam Washing Machine. I love this machine. It is a miracle of cleaning, especially since I own 4 large breed dogs and am washing and sanitizing large hairy and smelly bedding each and every day. And I no longer have to iron anything - I just use the steam cycle to unwrinkle our clothes. Best washer I have ever owned (and I have owned another major brand of large capacity front loading washer before - no comparison).
May 15, 2008 | LG WM2688H Front Load Washer
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
New LG WM2688H*M Steam Washer
Your load is unbalanced, at least that is what is sounds like. Have you taken out all the shipping bolts?
These washers and dryers hold very little clothing, 3-4 pair of jeans or less if the person is really large and maybe three regular sized thick bath towels since they weight so much when wet. You must make sure you are not overloading your machines when in use.
Good luck and if you keep having problems I would take a look at the manual and call customer service to report this issue to them. Make sure you get a repair number for your records.
Jan 14, 2008 | LG WM2688H Front Load Washer
LG WM-2277HW Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
