Question about HP DeskJet 9800 InkJet Printer
Power loss to HP Deskjet 9800
I moved the printer from one area of our RV to another, plugged it in, all was well except suddenly my laptop didn't recognize the device. In the interim, my husband started the engine of the RV, which changes the power source. The unit was still on when I unplugged it again, hoping that it would reset and be recognized by my laptop. I plugged it back in, and now can get no power or power light! I have checked everything, and all circuits, outlets in the coach are fine. Is there a reset button, something I should be doing, or was this on the way out anyway? It's only 4 months old, but I have had a myriad of problems with it compared to my last wide format unit, the 9650.
  • Anonymous May 07, 2009
    The green light on the back of the power point is on, but printer won't switch on.
  • 628 Answers
I think you blew it when the power source switched. When you try to power it up and don't get any lights, that usually means that the power supply in the printer is shot. Sorry. You might try getting warranty service on it.
Posted on Dec 01, 2008
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
Tripped over printer cable. Deskjet 9800 won't print. How do I remove the cover to examine the jack?
Unplug from power source and from power supply and remove a small philips screw driver the screw holding the power supply pack in rear of printer. Examine power supply for cracks, reinstall and try againg.
You may need to replace power supply unit.
Jun 12, 2010 | HP DeskJet 9800 InkJet Printer
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will...
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet 9800 Printer does not recognizes the cartridge and red light blinks even when the HP 97 (right cartridge) is installed. I have cleaned the contact area with Swab/alcohol but still it does not...
Take out the cartridge and examine the wire ribbon in the cartridge assembly. Many HP DeskJet 9800 users reported the ribbons getting damaged/punctured while installing or removing ink cartridges.
If that's the case your solution is to order part #C8165-67061 (google it) and install the entire assembly yourself. Be prepared that these items are delicate and some common sense is required.
You can also take the printer in for service to your local "big-box-electronic" store. This might not be cost effective so make sure you do your homework.
Jul 21, 2009 | HP DeskJet 9800 InkJet Printer
Printer does not see the cartridge
mine did that a year ago try to reseat the cartridge take it completely out and place it back in
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
How can i reset hp deskjet 9800
This happened to me and it was such a simple fix, I forgot to pull off the tab at the bottom of the cartridge. I hope this is your problem also.
Aug 01, 2008 | HP DeskJet 9800 InkJet Printer
Installing 9800 printer
Check on HP's technical support page, they usually have the software for the printer there.
Jun 18, 2008 | HP DeskJet 9800 InkJet Printer
9800 won't print
turn the cheeky thing off, unplug it, all cables, replug it. Try again once back on. Did it work? If not, try uninstalling it and reinstalling it. Good luck
Aug 29, 2007 | HP DeskJet 9800 InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
256 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
