Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco Primea Touch Plus flow problem
In your solution to a the flow problem reduced to a drop you wrote: "Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased". How can I do this?
Thanks a lot.
    Sergeant:
  • Saeco Expert
  • 223 Answers
In the bean hopoer there is a little screw. Remove this screw and the cover and you will see an adjustment alan key. You need to push down and rotate the adjuster counter clockwise to make it finer and clockwise to make it bigger. Make sure you only rotate the grinder a little at a time, 1/4 turns at a time recommended. Make 2 cups then readjust if necessary.
Saeco Authorized Sales & Service of Espresso Machines
www.CeriniCoffee.com
Posted on Nov 30, 2008
What is problem of coffee grinder not working
if the machine is ready to go and the grinder not start check to see if is not block the grinder blade and if not block change the grinder with the same voltage one 120V or 220V
Feb 18, 2015 | Saeco Primea Cappuccino Touch Plus Coffee...
Wet Pucks
The best way is to wait until the grinder is running then turn to coarse or fine.
Feb 28, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Grinder jammed
I'll explain how to in general, you have to work out the rest...first remove 3 screws on the coffee container...and 3 again underneath.To remove the sides..undo 6 T10 screws on RH side and 3 on LH.Then pull the front knob off and remove the coffee spout.Remove the top cover.Check the grinder whether itis accessible from the top ,if not remove 5 phyllips screws that hold the top half.Lift up and pull the grinder out. Good luck!
Jun 18, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
My saeco primea touch plus cappucino grinds coffebeans, but no co
prime the machine they give a little pump in the kit remoe water tank fill pump insert it in the hole apply pressure it should prime itself try opening the side valve to vent the machine let me now pierre
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
363 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
