Question about Sylvania SRD3900 DVD Player/VCR
Sylvania srd3900 error 2
Every time we put in a vhs tape error 2 comes on the display. Tape will not play, rewind, fast forward, etc. What causes this? Thank you....
  • 1 more comment
  • Anonymous Dec 13, 2008
    everytime i try to play a dvd the machine turns on, displays load dvd then switches back to err 2. i do not have an owners manual to guide me through this problem. can you help me?
  • Chas77 Dec 26, 2008
    Same problem on my unit
  • Anonymous Mar 19, 2014
    WILL NOTPAY VHS TAPE GOT ERROR 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Posted on Jan 03, 2009
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Error 2
my vhs/dvd combo sylvania shows error 2 how do i fix this
Nov 15, 2007 | Sylvania SRD3900 DVD Player/VCR
Sylvania SRD3900 DVD Player/VCR Logo
631 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
