Question about SanDisk Sansa e270 MP3 Player
It just died
Hello, After the song finished, the backlight of my Sansa didn't work and neither did the sound. When I turned it off to reset it, it doesn't power back on, but the blue light on the wheel still lights up when you touch it. Please help! I'm working overseas and don't have my CDs with me. I'd really like to listen to some tunes.
I had the same problem. it seems like the sansa e200 series has had lots of flaws and defects which really sucks. what i did was let the power drain. let the power drain and when you see that the blue light is off try to recharge again. or if it freezes, let the power drain and let it recharge
Posted on Feb 11, 2007
C150 as not working what's solution?
Check the orange "Hold" switch on the left side of the Sansa C150, if you cannot turn on the MP3 player or if none of the buttons is working. When the "Hold" switch is up, the buttons are disabled. Slide the "Hold" switch down to activate the buttons again.
Press and hold the "Power" button until the LCD screen lights up when turning on the MP3 player. Pressing the button quickly does not turn on the device. The "Power" button is located on the front of the device, under all the other control buttons.
Replace the AAA battery, if you cannot power on your MP3 player. To replace the battery, remove the battery cover from the back of the device by pressing in on its tab and pulling it off. Remove the old battery, insert the new battery and replace the cover. One AAA battery provides approximately 15 hours of power for your Sansa C150.
Change the backlight settings to conserve battery life. This is useful if you find the battery loses power quickly during normal use of your Sansa C150. To change the backlight settings, choose "Settings" to bring up the "Settings" menu. Select "Display," "Backlight" and then a shorter backlight time. The backlight will shut off after a period of inactivity that matches your backlight setting.
5
Review your music purchases to understand what rights you've purchased to the content, if you are unable to play a track back on your Sansa C150. When you purchase music, it comes with certain rules for how you can store and play it. You may not have paid for the right to transfer the song to a portable media player.
6
Reset the Sansa C150 if it acts erratically or if you have other problems. To reset the device, open the "Settings" menu and choose "Reset All." Choose "Save" to finish restoring the MP3 player to its factory default settings. If you decide not to reset the device during this process, select "Cancel" instead of "Save."
~KenjiFox
Jan 07, 2011 | SanDisk Sansa c150 MP3 Player
When i turn my sansa fuze on it says "not enough space for music db please free 90mb"and turns back off..how am i able to get it to wrk again?
When the player is rearranging playlists of the music database, it is possible that there's not enough memory left in the player to finish the task.
Connect the player with your computer to delete some files, at least 90 MB, off the Fuze to make it work again.
When not having a backup of the songs, save them onto the computer first.
Here's the support site for Sandisk Sansa Fuze:
http://kb.sandisk.com/app/answers/detail/a_id/3249/session/L3NpZC93dDhKSlRaag%3D%3D/sno/0
Directly to the Sansa Fuze user manual:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Need more help ? Just add a comment.
Apr 20, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb lockec
First of all, may I ask if you have a mini disc player or a Sansa Clip? Because the Sansa Clip does not play discs of any kind.
If you do indeed have a Sansa Clip you will find the FAQ rather helpful here - http://www.sansa.com/support/sansa_clip/faqs
Question 9 there is regarding devices not recognized by the PC and the solutions are as follows:
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
Clip: Go to Settings > USB mode & choose MSC
If none of the solutions work for you, please post the results of your attempts and we can go from there.
Dec 27, 2008 | Audio Players & Recorders
Sansa shaker mp3 wont play songs
Make sure the songs are in the right file format first. I would only download songs that are in mp3 format for starters. If it is still not playing, follow the reset method that the manual suggests. If it is still not working, it may be defective. These "windowless" players are the most difficult to use, because there is no on-screen display to let you know what's going on.
-Tha Mp3 Doctor
Dec 07, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
My Screen fades away!!
I might know how to finish that problem
I think you might have to go to settings in the sansa and go to backlight. Then choose On.
If this isn't what i'm talking about, try looking for another person that helps.
Hope i helped!
Dec 07, 2007 | SanDisk Sansa e270 MP3 Player
Sansa mp3 froze
IF the other solution doesnt work, you can try putting it into Recovery Mode, just to unfreeze it.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button for a few seconds.
If you see Welcome to Recovery Mode, let go of the Record button and hold the power button to shut it off. Then restart it.
Best of Luck.
Nov 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 not working properly
hold the power button for 20-30 seconds and that will reset the player
Nov 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
