Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Troubleshooting Mitsubishi WD-62327 62 in. Rear Projection HDTV
Vertical Lines have begun to appear, they are not there this morning. They show up later in the day. The TV is on an average of 4 hours during the week & 7 hours on weekends. What should I try & if that doesn't work what is the next step to do.? Thanks for your help.
There are filters that need to be cleaned first off. Then I checked with some people in the TV Repair Business & they gave me for FREE some helpful hints before pursueing expensive repairs.
Posted on Dec 02, 2008
Mitsubishi 52" gray vertical lines appeared then
no 200v for video line open low value resistor for the 200v
Oct 17, 2011 | Mitsubishi WD-52525 52" Rear Projection...
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Vertical lines showing in picture, especially noticable on black
in these issue you can see vertical lines due to filter capacitors bad in the secondary power supply. 100micfarad/j35volts, 220microfarad/25volts.
Jun 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Vertical Lines on my 3 year old WD-52725
I believe the format, or FMT board is going bad. this is not a do it yourselfer type repair, unless you have extensive electronics background - I have one myself with the same problem. I am waiting to get a new FMT board for mine.
Dec 17, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Vertical lines WD-62525
Most likely the formatter board. Are these lines across the whole screen?
Mar 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
228 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
